steve m
posted on 21/8/10 at 11:48 AM |
New drill required, but which one ?
My trusty, but well well used Bosch 240v drill, has died, and is now in the bin!!
which new one should i buy ?
It will only be used for household/car related uses, so industrial quality not required
whats the verdict ?
PSpirine
posted on 21/8/10 at 11:52 AM |
Bosch again.
peteday_uk@btinternet.com
posted on 21/8/10 at 11:57 AM |
I went with a Makita as they were on offer 18v for £99 with two batteries.
Pete.
Stott
posted on 21/8/10 at 12:04 PM |
This is what I've got:
BOSCH DRILL
ARGOS BOSCH DRILL
Cracking little drill, and small enough to fit in tight spots. IIRC it's the best DIY one Bosch do before the case size goes up one and they get
almost 2" longer.
I think they are about the £35 mark new from the staff shop in work (I work for Bosch) So both of those are good price.
I'd be inclined to pop to argos for that one as there's no postage cost and if it knackers up you can return it easily
Stott
steve m
posted on 21/8/10 at 12:16 PM |
That one looks like an up to date of the one ive just thrown, so off to Argus to get one!!
thanks
stevebubs
posted on 21/8/10 at 12:40 PM |
Have you considered a cordless one? The Bosch ones are stonking for working on the car....
Jasper
posted on 21/8/10 at 12:50 PM |
Yeah - but sometimes you just need that 240v power
posted on 21/8/10 at 12:51 PM |
Haven't used my mains powered drill except for mixing plaster etc since buying a cordless.
balidey
posted on 21/8/10 at 01:09 PM |
I went cordless about 10 years ago, not took my mains one out of its case since.
I made the (huge) mistake of getting a cheapy cordless drill. When I moved upto a Makita 18v combi drill it puts the corded and the cheap cordless to
shame. Best £80 I had spent in a long time.
Dutch bears have terrible skin due to their clogged paws
PSpirine
posted on 21/8/10 at 01:12 PM |
The linked one is what I got from Homebase a couple of months ago (I think it was about 35 quid on offer).
Absolutely superb drill IMHO.
I echo everyone's suggestion that if you get a semi-decent proper cordless you don't need a 240v jobbie, but that depends on what you want
to do.
I needed to make a fair few holes in concrete and the 240v handled it no problem. The cordless I used did it, but took at least 5 times as long per
hole. Similarly with cutting large diameter holes in wood/steel - it's nice to have the extra torque of a proper drill.
v8kid
posted on 21/8/10 at 01:25 PM |
Life would be intolerable without a cordless. Slower but taking set up time into account quicker.
Makita are the best I've had
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
geoff shep
posted on 21/8/10 at 01:32 PM |
The new cordless drills with Li-ion batteries are great. None of the battery memory/running down problems of old and they fast charge - and hold the
charge. Just like mobile phone batts. Got a bosch from B&Q which is great.
Stott
posted on 21/8/10 at 04:20 PM |
I've got 3 cordless, 1 small mains (as posted above) and an sds.
Cordless are great but if you're building a decking and putting 12mm flat wood bits through posts all day, you need the mains one.
But the biggest reasons for the mains IMO are drilling small diameter holes (which our cars require lots of) because, for instance my bosch 24v
cordless only does 1800rpm, whereas the mains does 3000rpm, meaning cleaner holes, quicker, and with half the wear on the bits. Cordless drills just
don't go fast enough.
The second reason is when using wire brush/mop accessories, these are pretty useless in a cordless.
IMO mains drills are indispensable, cordless ones are great and you can manage with them, but if you could only afford to buy one, it would be a mains
every time for me.
Stott
fesycresy
posted on 21/8/10 at 04:59 PM |
A lad in work bought an Aldi / Lidl special.
Everyone took the p1ss. After probably 6 years it's still going strong!
Spend a little extra and get a Makita. That's pretty much all you see on site these days.
steve m
posted on 21/8/10 at 05:06 PM |
thanks for the respons's were would we be with out this site !
I have a 12v cordless for winding the caravan legs up an down and menial jobs
around the house
but a 240v in the tool box allways (to me) seems the way to go
posted on 21/8/10 at 07:09 PM |
every time for me.
Stott
Spot on there, that corded drill will wee all over cordless drills many times as expensive. For £40, coupled with a £60 cordless, you will be much
better off than someone with a £100 cordless.
whitestu
posted on 21/8/10 at 07:17 PM |
I've got an Aldi 240v one, which was £12 ish and Lidl cordless for £35 with 2 batteries. Both are spot on for the money. IMHO Bosch are crap.
But Hitachi / Makita if you want quality.
Stu
Madinventions
posted on 21/8/10 at 10:59 PM |
All the batteries died for my cheapo cordless drill, so now it's got a 4mtr lead to a spare car battery. Lasts forever! Ok, so it's not
exactly cordless anymore, but it's still easier than trying to find a long extension lead in a hurry.
I've also got a £20 B&Q cheap corded drill and it's fantastic for the price. The last one I had lasted about 4 years until the
bearings died and it help build 1 kit car, 2 workshops, a chicken run and countless other projects so it didn't do too badly.
In the end, I'd rather chuck a worn out cheap drill than an expensive one. My wife has got one of those posh Makita Li-On 18V jobbies and
it's brilliant, but I daren't use it on my stuff in case I break it. I could buy 15 of my cheap 240V drills for the price of one of
them...
Ed.
View my band website:
http://www.shadowlight.org.uk
