Author: Subject: Haynes roadster suspension
scutter
posted on 21/8/10 at 06:34 PM Reply With Quote
Does anyone know of any flaws in the rear suspension of the Haynes roadster?
Just been given a sierra rear axle and i can never stop fiddling with the car.
ATB Dan.
nnrouty
posted on 21/8/10 at 06:37 PM Reply With Quote
i know that one of the book issues had the wrong dimension for the rear wishbones. They were 10mm shorter then the needed to be.
As long as its fast.... i don't care
Ben_Copeland
posted on 21/8/10 at 06:42 PM Reply With Quote
First edition book only tho... IIRC second edition is correct
Ben
Locost Map on Google Maps
Enter Your Details Here
interestedparty
posted on 21/8/10 at 07:29 PM Reply With Quote
You need to get on the Haynes forum, corrections advice etc available there
hellbent345
posted on 21/8/10 at 07:35 PM Reply With Quote
if you are talking issues with its performance, id say one problem is it has no facility for changing toe...
snapper
posted on 21/8/10 at 07:57 PM Reply With Quote
You can change toe by packing the hub flanges with washers as the short oval racers do
I eat to survive
I drink to forget
procomp
posted on 21/8/10 at 10:06 PM Reply With Quote
Hi
The main problem is there's no triangulation in the rear section of the chassis. The geometry could be right static but flex will see it moving when loading is placed into the chassis.
And as mentioned add toe adjustment into the wishbones rather than the hubs.
Cheers Matt
scutter
posted on 22/8/10 at 06:01 AM Reply With Quote
Thanks for the replies, So a cheeky mod to the wishbones and something along the lines of the Cat CSR chassis for bracing as below and it should be good.
This should keep me busy for the next year.
Many Thanks Dan.
