New Topic New Reply
Author: Subject: Sikaflex
Macbeast
posted on 29/8/10 at 06:11 AM Reply With Quote
Sikaflex
Is Sikaflex available in DIY stores under another name ? I can't keep running down to CBS and it would be nice to have some for tomorrow anyway.
adithorp
posted on 29/8/10 at 06:44 AM Reply With Quote
Good motor factors should have it. If they don't stock Sikaflex ask for TigerSeal or just Polyurethane adhesive.
My local factor stocks PUflex.
adrian
http://jpsc.org.uk/forum/
bartonp
posted on 29/8/10 at 08:07 AM Reply With Quote
I used this stuff:
http://www.marinemastics.com/marine-flex.html
Data sheet has it comparable to Sika 291, miles cheaper... works too!
bilbo
posted on 29/8/10 at 09:21 AM Reply With Quote
It might also be worth looking in Caravan places if there's one near you, as they sometimes stock it as well.
There's a Caravan place near me which I use when I run out and need some there are then. More expensive though
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
Chippy
posted on 29/8/10 at 11:24 AM Reply With Quote
Builders merchants often stock Evo products that work very well, "Sticks like S**t" works for me, but they do do others as well. HTH Ray
Edit to add, Evo "Serious Stuff" is another that is good.
[Edited on 29-8-10 by Chippy]
Macbeast
posted on 29/8/10 at 04:20 PM Reply With Quote
Thank you all
Krismc
posted on 30/8/10 at 07:20 PM Reply With Quote
Clear silicone is the stongest stuff if not visable as its very strong and still flexible. make sure its solvent based though for a clean strong bond.
My window in transit is held in with clear silicon.
alistairolsen
posted on 31/8/10 at 10:11 AM Reply With Quote
silicon is nothing at all like polyeurathane and your windscreen certainly shouldnt beheld in with it!
My Build Thread
posted on 1/9/10 at 04:31 PM Reply With Quote
sikaflex is sold by Travis PEerkins - well, at least my local one does since I have purchased 2 tubes from them.
Macbeast
posted on 1/9/10 at 08:24 PM Reply With Quote
Just bought two tubes from CBS. Surely that's the last ??
dhutch
posted on 9/11/10 at 11:55 PM Reply With Quote
Originally posted by KrismcMy window in transit is held in with clear silicon.
Ouch!
wicket
posted on 10/11/10 at 11:59 PM Reply With Quote
We used Loctite 5222 white (also available in black and grey I believe), very similar; been fine for nearly 8 years now.
MikeR
posted on 11/11/10 at 12:07 AM Reply With Quote
Kris - please take the window out and get it bonded in properly. Windows in modern vehicles form part of the structure hence are bonded in. If its not bonded in - you've potentially got a seriously weakened structure and could find yourself in a lot of trouble if you ever need it.
breezy
posted on 12/11/10 at 04:32 PM Reply With Quote
Hi Folks
Just to say Honda dealers use Sikaflex221 for bonding panels etc together. The Honda part number is 07SIKAFLEX221HE and sells for about £14 a tube.....hope this helps.
You've turned into your dad the day you put aside a thin piece of
wood specifically to stir paint with.
New Topic New Reply
