Author: Subject: FS: Locost 2.1 Pinto
Hugh_
posted on 5/9/10 at 04:26 PM Reply With Quote
I am selling my Locost Kitcar as since finishing its rebuild I haven’t used it anything like as much as I should have. I bought it September 2008 as a part rebuilt project. The rebuild included an engine change (CVH – Pinto), new suspension, new brakes, new LSD, new interior, complete rewire and various bits of bodywork. The V5 has been updated with the new engine size. The car was built and SVA’d in 2001, it is on a Q plate and due to the age of engine only needs a visible smoke test at MoT time.
The MoT runs to May 2011 and the tax to the end of April 2011. The car has 2 previous owners, the original builder and one other who drove it briefly before starting the rebuild. I have a file full of receipts and instructions, and loads of photos, the megajolt maps etc. which I will put on DVD.
Bodywork/Chassis
• Spaceframe chassis built to Ron Champion book specs.
• GRP cycle wings and nosecone
• Alumimun scuttle, bonnet, rear and side panels
• Aeroscreen (fitted) and windscreen (crack in one corner, and no wipers fitted/wired at present).
Engine
• 2100cc Pinto, 1000miles since rebuild
• Shortened and baffled sump.
• Kent GP1 Camshaft kit
• Big Valve Head – Group 1 spec (1 Ύ inches inlet (44.4mm) and 1 ½ inches exhaust (38.1mm))
• Lightened flywheel
• Alloy vernier Pulley
• PowerLite Gear reduction starter motor
• Denso lightweight alternator
• Burton rear fill cam cover
• PCV valve replaced with breather elbow to alloy catch tank
• New CBS 11” fan mounted to new Polo radiator
• New waterpump
• Twin Dellorto DHLA 45s rejetted to suit and initial tune by Gerald Dale Motorsport
• Facet Posiflow fuel pump with inertia cut-off and filter king regulator
• 4-1 Manifold with 6” stainless steel silencer
• Pipercross PX600 air filter and backing plate
• Megajolt ECU
Transmission
• Type 9 gearbox
• New clutch kit fitted during rebuild
• Rally Design Type 9 turret extension and short shift gearstick
• Live “English” axle with 3.77 with Quaiffe ATB limited slip diff.
Steering/Suspension
• Spax coilvers with polybushes
• Mk2 Escort sterering column
• OBP floor mounted pedal box: clutch (cable) and twin m/cyl bias adjustable brakes with dash mounted adjuster
• Wilwood Powerlite 4 piston with 265mm sold discs and Mintex M1144 Pads @ front with braided hoses
• 7” drums at the rear
Electrical
• Car completely rewired during rebuild
• New Denso lightweight alternator
• New battery
• Smiths speedometer and rev counter (matching) and Racetech electronic fuel, oil pressure and water temp (all with correct senders), speedo cable with (very expensive) right angle drive and cable made up with correct end fittings.
• Bright6 LED warning light array and savage hazard switch
• Small “Dominator” headlights
• 12v socket
• High level rear brake light.
Other…
• Team Dynamics Pro Race 1.2s 15x6.5 with Durun Sport 1s and spare Yoko A539s (not fitted)
• New ali transmission tunnel side panels, and leatherette covered ali tunnel top and dash.
• GRP seats with 4 point harnesses
• Racetech centre rear view and wing mirrors
• Solid rear boot cover
• Fitted neoprene over roll bar rain cover
• 25 Litre fuel tank
• Fire extinguisher in passenger footwell
Lots of money spent and I really enjoyed rebuilding it, but I haven't got the time to use it.
Sensible offers IRO £5,500 please.
07743 495840
The car is in Kent.
1
1
2
2
3
3
4
4
5
5
6
6
7
7
Image deleted by owner
8
8
[Edited on 5/9/10 by Hugh_]
Hugh_
posted on 7/9/10 at 06:46 AM Reply With Quote
Nothing at all! Any comments on whether it's fairly priced greatfully received.
Hugh_
posted on 9/9/10 at 12:07 PM Reply With Quote
One other picture that I forgot
9
9
[Edited on 9/9/10 by Hugh_]
Hugh_
posted on 12/9/10 at 02:24 PM Reply With Quote
Bump
posted on 12/9/10 at 09:04 PM Reply With Quote
Really good lucking car. Good luck with the sale.
Can I ask about the rain cover? Did you make it your self, looks just what I need.
Hugh_
posted on 13/9/10 at 08:01 AM Reply With Quote
Thanks Coozer,
Yes I made the cover myself, I was going to do a tonneau but didnt think I'd do a good job around the high-back seats. It's 4mm neoprene from eBay (search wetsuit neoprene, not neoprene rubber, I made that mistake!) but 2.5 or 3mm would probably be fine as well.
I cut it roughly to size -15% to allow for stretch, then sewed the edges on a sewing machine. I eventually found that it worked best using a fairly high foot pressure, with a low-medium thread tension, a needle designed for sewing jeans and nylon thread.
The front and rear attachments are on loops of webbing, and poppers on the sides are straight through the neoprene. The webbing is hand sewn as the sewing machine wasnt man enough to do neoprene and webbing...
I'm fairly pleased with it and it certainly does the job. I think size - 10% would have been fine though, and I should have planned better what to do at the back as it still has corners which I just tuck under the cover, if they were removed then It would be difficult to get it to seal against the boot top.
Hope that's some use.
Hugh
Hugh_
posted on 17/9/10 at 06:58 AM Reply With Quote
bump
Hugh_
posted on 20/9/10 at 11:16 AM Reply With Quote
bumpety bump
Hugh_
posted on 25/9/10 at 09:43 AM Reply With Quote
Weekend bump
posted on 25/9/10 at 11:45 AM Reply With Quote
suprised it hasnt sold, looking that tidy. Have you had any cheeky offers?
beaver34
posted on 25/9/10 at 01:22 PM Reply With Quote
looks a nice well built car and cover seem a great idea, might make one for mine!
Hugh_
posted on 14/10/10 at 02:08 PM Reply With Quote
Price dropped to £5000
I was going to wait until spring but I'm seriously considering buying a house again.
[Edited on 14/10/10 by Hugh_]
Hugh_
posted on 21/10/10 at 10:02 AM Reply With Quote
bump
