Author: Subject: Engine age and catalyst - not what you think !!
pdm
posted on 7/9/10 at 08:08 PM Reply With Quote
Hi
I am writing off to Mazda to get proof of engine age for my MX5 donor.
It was declared manufactured 1992 according to the V5 so I am fairly sure it is. I also checked on a japanese site and that also came back March 1992.
IVA manual says:
"The “effective date” used to determine the criteria applicable is the
date of manufacture of the vehicle, except for an “Amateur Built” vehicle, a “Vehicle manufactured using parts of a registered vehicle” or a “Rebuilt vehicle” it shall be 1 January immediately preceding the date of manufacture of the vehicle’s engine if this is earlier."
So first I am correct in thinking my engine's effective date is 01/01/1992 ?
That should put me "Start" section of IVA emissions test as my effective date can be no later than March 92 - no need for BET at all ?
Second question though I am not clear on - my car has a catalytic convertor - piccy at:
http://www.flickr.com/photos/41418507@N08/4964550625/
So in my letter from Mazda do I need to get them to confirm whether or not it had a cat. If they write back saying it had a cat on it, will I still need to fit a cat to my kit even though my engine is pre 1992 ?
Finally - because it's a Eunos it hasn't got the engine number on the V5. I've asked Mazda if they can link the engine number to the VIN (here's hoping it hasnt had a replacement engine !!). Do you think this would be ok for DVLA come registration time with a view to getting an age related plate.
Although I'm half of a mind to just let bureaucracy take it's course and get a 'Q'....
Any advice gratefully received especially if you've registered with similar circumstances.
thanks folks,
Paul
matt_claydon
posted on 7/9/10 at 08:33 PM Reply With Quote
Engine age is all that matters for amateur-built bIVA. Just get Mazda to confirm the date and you will get the easy test.
Between 1992 and 1995, some cars had cats and some didn't, depending on when models were updated etc. For amateur builds VOSA keep it simple and assume all cars were non-cat.
pdm
posted on 7/9/10 at 08:34 PM Reply With Quote
Thanks Matt
DavidM
posted on 7/9/10 at 10:06 PM Reply With Quote
To get an age related plate you only need two major components from the donor car, assuming you have the V5, and be building using a new chassis "from a manufacturer." The two major components generally include the engine, but do not have to.
Proportion is Everything
