doddy
posted on 14/9/10 at 01:11 PM |
wanted 15mm Alternator Pulley 6 grooves
hi im after a Alternator Pulley with a 15mm bore need 6 grooves for zetec
its going on a Brise alternator
any help would be good
i have a v one if anyone needs that
cheers ian
[Edited on 14/9/10 by doddy]
posted on 14/9/10 at 01:38 PM |
Try speaking to a few alternator refurbishers. I found one via ebay and got a load of pulleys for not much cash.
posted on 14/9/10 at 02:48 PM |
i have zetec alternator that has a grooved pulley - not sure how many grooves.
check with nnrouty as although he did not want it, hes is getting it as I cannot be bothered storing bits and pieces that I cannot see myself
using.
doddy
posted on 14/9/10 at 02:57 PM |
i have a zetec one cheers but they have a 17mm center i need 15mm i might just but a spacer in it if i cant get one
Mix
posted on 14/9/10 at 04:02 PM |
Hi
I think you'll find a lot of the Japanese vehicles in your local scrappy will have 15mm bore 5x poly vee pulleys - just use a 5 vee belt, I know
I'm going to.
Regards Mick
