Author: Subject: VX220 Stack Dash Fitment...
posted on 15/9/10 at 12:50 PM Reply With Quote
Booger... went to edit the last post on the previous thread and ended up deleting the whole bally lot it in error! Space Cadet!
Anyway... my dash arrived. Came from a 2002 VX220.
Image deleted by owner
I've looked at the few VX220 dash transplants on the web, but all the instruments differ from mine! Not too fussed about the face - it's the back where it's at!
Only 1 connector-slot instead of the 2 on all the other threads!
I'm trawling away trying to find any tech docs with the numbers on the back of the unit. I also found the following numbers inside the casing (along with two silica gel sachets!):
ST9100
ST100097
97-005
LC01-20
They're not flagging up anything on Google either!
Not a disaster as I'm hoping this is one of the 'old' units like the ones they used on the S1 Elise - makes things easier if it is, but just have to confirm it!
It's Evolution Baby!
rayward
posted on 15/9/10 at 01:10 PM Reply With Quote
think i've got a wiring diagram somewhere for the mk1 elise dash, if thats any help ?
Ray
loggyboy
posted on 15/9/10 at 01:35 PM Reply With Quote
Thats a genuine stack dash, my VX220 was a 'non branded one' with a tornado name on the back.
This is the info I got from the SELOC site:
You basically have 3 options for 'non-STACK' dash units:
- Late S2 Elise rover engine (part number A117....)
- VX220 Turbo (part number A116...)
- S2 Elise Toyota engine (part number A120...)
The first 3 should have 1 plug on the back and have discrete inputs for the various gauges/lights. RPM range to 8000 for the Elise. Not sure for the VXT (7500?)
The Toyota version has CAN input and needs to be hooked up to an ECU with the proper CAN data port. RPM range to 9 or 10000 rpm on the dial.
Heres the wiring diagram I used
http://www.speedsterclub.nl/bibliotheek/technische%20documentatie/tis/Wiring%20Diagrams/Body%20System/Instrument/Circuit%20Diagram/Instument.pdf
posted on 15/9/10 at 01:43 PM Reply With Quote
Cheers guys!
Buuuuuut... just found THIS and it would seem to confirm that this unit is the same as the Elise S1's.
[Edited on 15/9/10 by scootz]
posted on 15/9/10 at 01:44 PM Reply With Quote
Ray... that would be if you could send me details!
Cheers!
Fozzie
posted on 15/9/10 at 02:25 PM Reply With Quote
Scootzie, have a look on here :-
http://www.vx220.org.uk/
A minefield of info ....
Fozzie
posted on 15/9/10 at 02:27 PM Reply With Quote
Cheers Fozzster!
davestarck
posted on 15/9/10 at 05:47 PM Reply With Quote
Its not from a VX220 turbo has it does not have a shift light on the rev counter if that helps
Dave
posted on 15/9/10 at 06:11 PM Reply With Quote
Cheers Dave!
Fozzie
posted on 15/9/10 at 06:18 PM Reply With Quote
Dave
Dave, you are right, but as Scootz said it was from a 2002 220, and the Turbo wasn't out then, I assumed he knew it was from a NA..........
Soz Scootzie, my bad ..... I should have confirmed ....
Fozz
posted on 15/9/10 at 09:29 PM Reply With Quote
Originally posted by scootz
Cheers guys!
Maybe not!
The lads and lasses at VX220.org reckon the one I have still receives PWM signals
Fozzie
posted on 15/9/10 at 10:34 PM Reply With Quote
'im indoors is at Goodwood revival until Sunday, and he knows far more about the vx220 than moi ....
But I know he also looks at this site...its the speedster (opel name for the vx220) site in Holland ......
LinkyDink
Hope this helps a bit
Fozzie
posted on 16/9/10 at 08:39 AM Reply With Quote
Ta Fozz!
westy turbo
posted on 16/9/10 at 01:16 PM Reply With Quote
iam doing mine this week so i keep u posted
posted on 25/9/10 at 08:32 AM Reply With Quote
I've ordered an Elise S1 cluster as it has the 'normal' signals.
Sooooo the VX220 one is available to anyone with a more electronically-gifted disposition than I?
McLannahan
posted on 25/9/10 at 08:36 AM Reply With Quote
Let me get this right Scotty....You've bought something, didn't use it and now you're selling it again at a loss??
There's something about that that rings a bell?
Just can't put my finger on it.......
posted on 25/9/10 at 08:39 AM Reply With Quote
Nope... I'm going to make a profit from it!
I want...
RK
posted on 25/9/10 at 05:06 PM Reply With Quote
that's what we all say.
posted on 25/9/10 at 06:03 PM Reply With Quote
... but I'll accept £100
posted on 1/10/10 at 01:08 PM Reply With Quote
Arrived today - a bit more expensive than the VX220 dash (£185 v £125), but it comes with a harness and crucially... I CAN GET IT TO WORK!
Had a look at the original 'Lotus' price for the part... £1600
Anyway, I plan to find some material that matches the fascia and blank over the Lotus name and the seat-belt / cat-overheat tell-tales.
Will then see if I can use the alarm tell-tale to come on as a shift-light.
[img][/img]
daniel mason
posted on 1/10/10 at 07:36 PM Reply With Quote
send it to andyw7de and he will make a great 5mm ally pannel to slot them in! thats what i did.
daniel mason
posted on 1/10/10 at 07:40 PM Reply With Quote
this is what i got him to do!
[img][/img]
