Steve Lovelock
posted on 19/9/10 at 05:23 PM |
Sticking brake master cylinder - any ideas why?
I was sprinting the Luego today and during the third run I developed a problem with the bakes binding. I didn't actually realise something was
wrong until I was on the starting grid for the fourth run so just continued. By the time I'd finished it the brakes were on with some force. I
got back to the pits and started playing with the brake pedal and when I tugged it back the brakes instantly freed. I then drove the car home with
incident.
Any ideas why the master cylinder might stick?
It is a pedal box / balance bar set-up and has only done 3,000 miles so not exactly old. I know that the brakes take a hammering during a sprint but
I have done several events without trouble.
posted on 19/9/10 at 05:37 PM |
Sticking pedal pivot point, over adjusted push rods or needing a return spring on the pedal would be the first things to check
cairnnut
posted on 19/9/10 at 05:45 PM |
Hi steve You need to adjust to give a slight clearance between the actuating rod and the master cylinder to allow for expansion.
john
posted on 19/9/10 at 05:47 PM |
Is it a Sierra master cylinder? If so, it is very easy for dirt and grit to get into the bore and prevent the piston from returning fully and causing
the brakes to bind.
Phil
jacko
posted on 19/9/10 at 05:49 PM |
It could be the seals in the m/cylinder that are letting oil pass them stopping the peddle returning
posted on 19/9/10 at 05:56 PM |
Quite often it is the mushroom on the end of the pushrod is too big and fouls the stop washer at the end of the cylinders.
posted on 19/9/10 at 05:57 PM |
the brakes to bind.
Phil
Not unknown --- easy enough to check.
posted on 19/9/10 at 06:00 PM |
Not really but one thing that it could be is too much fluid in the reservoir. An air space is required to allow for fluid expansion when hot.
austin man
posted on 19/9/10 at 06:38 PM |
over adjustment
crap under pedal
angle of rod into cylinder
then what everyone else said
Steve Lovelock
posted on 19/9/10 at 08:26 PM |
Thanks for the advice. I'm going to look at the bias bar set-up first as I know that's not what it should be.
Steve Lovelock
posted on 26/9/10 at 03:50 PM |
I had a look at the set-up today and discovered that the plunger shaft for the front master cylinder was bent. I also realise that the set up
wasn't true which probably contributed to the distortion. Think I have it sorted now.
