Breaker
posted on 22/9/10 at 08:48 PM |
Indy R fuel tank
I'm almost ready for welding my alu fuel tank. It should fit in a MK Indy R with full roll cage.
Can someone help me with some dimensions for the tank or some pictures ? Thanks !
Davegtst
posted on 24/9/10 at 10:13 AM |
This is what mine looks like. It's from MK but yours might be slightly different as my rollbar isn't standard.
Breaker
posted on 24/9/10 at 11:54 AM |
Thanks for the picture ! How will the tank be attached to the chassis ?
Davegtst
posted on 24/9/10 at 05:51 PM |
Tigerseal apparently. Mk reckon you don't need straps anymore. I've used tigerseal before and it is extremly strong so i can't see
a problem.
martyn_16v
posted on 26/9/10 at 05:00 PM |
MK Fuel Tank dimensions
This is the 'normal' tank, as mentioned it's stuck to the chassis rails with PU adhesive.
Breaker
posted on 26/9/10 at 07:39 PM |
Thanks !
