maskell01
posted on 23/9/10 at 06:36 PM |
Lost bolts..........
during the madness of the build ive misplaced a nice selection of bolts.......
all the rocker cover bolts for a pinto engine(are these standard across the pinto?)
and 2 of the propshaft bolts i will replace them all but any clues as to with what size and thread?
cheers
gavin174
posted on 23/9/10 at 06:51 PM |
you can buy some nice stainless rocker cover bolts on ebay..
prop bolts still available from ford
maskell01
posted on 23/9/10 at 07:07 PM |
so they are standard sizes then?
snapper
posted on 23/9/10 at 07:30 PM |
Prop shaft to diff flange bolts are a fine thread, not easy to find from the normal suspects.
Rocker cover bolts are a standard thread and I like to use cap head Allen ones.
The steel rocker cover likes the load spreading plates that come with the standard ford bolts.
I eat to survive
I drink to forget
mcerd1
posted on 23/9/10 at 08:28 PM |
the propshaft bolts are something like and M10x1.0 (fine thread)
I've got some spare if you need them...
posted on 23/9/10 at 09:06 PM |
IIRC the rocker cover bolts are M5 and a above it's best to use the proper load spreading washers with the pressed steel rocker covers.
Ebay usually has nice stainless sets on offer or you could try Burton Power for a set.
lotusmadandy
posted on 24/9/10 at 06:38 AM |
The cam cover bolts are standard m6 jobbies.
