maskell01
posted on 26/9/10 at 08:26 PM |
Boots for sensors
Im In need of help!
to finish my wiring loom i need the boots that push on to the coil pack,oil sensor and water temp sensor!
the little black connectors and boots, its for a pinto engine.
Any ideas where to get these from?
Aaron
RichardK
posted on 26/9/10 at 08:30 PM |
Scrappers for those I reckon, or heat shrink tubing could be used I suppose.
Rich
Gallery updated 11/01/2011
maskell01
posted on 26/9/10 at 08:41 PM |
yep i was thinking the same ..........thank you
Stott
posted on 26/9/10 at 08:47 PM |
I've got the same ones on my pinto and I reckon these would be a close fit, and far easier than finding a sierra with that particular management
in the yard:
LINK
HTH
Stott
EDIT: I read that you wanted Dizzy, and water temp sensor (in manifold one), I am a nob, Sorry.
Although, as stated I have the same lump, I used the coil ones that were on my loom, you could use nuts and crimp on loops though with generic boots
you can buy at any show etc. For the oil and water senders I used 2 different sizes of female crimp on bullet connectors, with a little black heat
shrink over them for asthetics, it wasn't needed for insulation as they were the red/blue/yellow type crimps so were pre insulated.
[Edited on 26/9/10 by Stott]
MakeEverything
posted on 26/9/10 at 08:57 PM |
www.polevolt.co.uk
Or
www.efi-parts.co.uk
Both have the boots in rubber and plastic.
Kindest Regards,
Richard.
