Author: Subject: Rolling at last.
Doug68
posted on 27/9/10 at 12:53 PM Reply With Quote
Rolling at last.
Here it is on its wheels...
Queue Limp Bizkit
Doug. 1TG
Sports Car Builders WA
rallyingden
posted on 27/9/10 at 01:58 PM Reply With Quote
WOW LOOK AT THAT ........................
I mean the sunshine not the car. Ha Ha
Seriously
Nice build
RD
RazMan
posted on 27/9/10 at 05:23 PM Reply With Quote
Nice! Have you got any detailed shots of the engine & trans? It must be a tight fit in there.
Raz
Fred W B
posted on 27/9/10 at 06:28 PM Reply With Quote
Looking good Doug, now for the fun part - bodywork!
What dimension front overhang are you planning? Looks pretty long in the pic.
Fred W B
TheGecko
posted on 27/9/10 at 09:37 PM Reply With Quote
Congratulations on hitting a significant milestone Doug. Look forward to seeing the progress on the bodywork.
Dominic
Doug68
posted on 28/9/10 at 01:40 AM Reply With Quote
rallyingden: Its Australia, sunshine and happiness is what we do
Razman: Yeah its a tight fit...
Engine Bay
Engine Bay
Fred W B: The overhang from the C/L of the front wheels is ~780mm (4" of ground clearance doesn't look like a lot once it's sitting on the ground).
TheGecko: I'm also looking forward to seeing progress on the body
[Edited on 28/9/10 by Doug68]
Doug. 1TG
RazMan
posted on 28/9/10 at 08:11 AM Reply With Quote
Doug - that looks really comfy in there! I would be interested to know any details you might have regarding the fitting of your combination. Does the trans mate up to the V8 with a standard adaptor (I presume its custom made) What sort of distance is between front of the engine to the driveshafts etc.
Soarer V8s are very cheap in the UK and my V6 is looking a bit tame recently - I sense a cunning plan coming on
Raz
Doug68
posted on 28/9/10 at 08:27 AM Reply With Quote
Hi Razman,
The flywheel - adapter are a custom combo to my design. They cost more than the engine to get made.
A transaxle with a detachable bell housing like a Renault UN1 might make life a lot easier to achieve the connection.
From the front of the crank pulley to the CL of the output flanges is ~840mm
BTW these engines are known to make 1000+ BHP with sufficient work, so it's just a question of throwing money at it until you're scared to put your foot down
Doug. 1TG
Angel Acevedo
posted on 28/9/10 at 04:44 PM Reply With Quote
Queue Limp Bizkit
Nice wheels, Brand and model?
Thanks.
AA
Doug68
posted on 28/9/10 at 11:33 PM Reply With Quote
Hi Angel,
These are the wheels used:
http://www.acealloywheel.com/product_1_1019.html
Roughly US$900 a set before shipping.
Doug. 1TG
coyoteboy
posted on 29/9/10 at 09:18 AM Reply With Quote
Hi, looks like a nice build, plenty of triangulation! A quick question - why the Toyota engine and box/block adapter when there are other similarly powered, cheaper available combinations? (Audi V8 springs to mind)
Doug68
posted on 29/9/10 at 12:53 PM Reply With Quote
Originally posted by coyoteboyA quick question - why the Toyota engine and box/block adapter when there are other similarly powered, cheaper available combinations? (Audi V8 springs to mind)
I live in Australia Audi's over here are and always have been stupidly expensive, so their V8 would be a lot of money to source.
The Lexus V8 on the other had is cheap as chips brought in 2nd hand from Japan.
Doug. 1TG
coyoteboy
posted on 29/9/10 at 04:40 PM Reply With Quote
Ah fair enough then, as I was looking at the 4.2V's myself as one possibility, and they come in fairly cheap for a full engine/transmission combination (around £1000).
Angel Acevedo
posted on 30/9/10 at 02:51 PM Reply With Quote
Hi Angel,
