Author: Subject: duratec 2.0 to type 9
tilly819
posted on 30/9/10 at 06:36 PM Reply With Quote
hi all
I am considering changing from my blackbird engine to a 2.0 duratec (dont ask why i now i must be mad)
i am wondering what is involved so for from some resurch i have established the folowing
bellhousing durtec to type 9 available from rally design about 165 quid
what is required in terms of clutch, flywheel, release mech and starter moter and is there anything elce that has to be changed on the engine for rwd configuration????
i am looking to do 200hp N/a with throttle bodies exhaust and management pos megasquirt need to look into that more though i now very little about megasquirt so any advice there would be good also
thanks very much
tilly
les g
posted on 30/9/10 at 06:53 PM Reply With Quote
No..No...No...No...
build a new car Tilly you know it makes more sense
cheers les g
tilly819
posted on 30/9/10 at 06:56 PM Reply With Quote
That has also been considered and may well happen but i think it will be duratec power rather than bike power i have another plan for the bike engine *grin*
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
big-vee-twin
posted on 30/9/10 at 07:08 PM Reply With Quote
You need the bell housing which you already know.
You need a flywheel from an ST150 unless that's the engine you buy.
You then need a RS Turbo clutch and a AP racing Heavy duty Pinto plate.
If using hydraulic clutch a slave cylinder from a Saab and Thrust bearing
You then need a lowered sump
If you want throttle bodies either GSXR 750 on a bespoke inlet manifold (Fastdan can make you one) or Jenvey.
You will need to relocate alternator to opposite side so some brackets or make them and a compact Denso alternator.
Tensioner pulley from Ford Focus
Starter from a Focus or Fiesta as Mondeo Flywheel a little thicker
Think that's about it
Oh and read Flak Monkeys thread
Duratec to Type9 Bellhousing
http://www.triangleltd.com
tilly819
posted on 30/9/10 at 09:18 PM Reply With Quote
fantastic thanks
tilly
