maskell01
posted on 4/10/10 at 09:02 PM |
Throttle cables
I will be running my pinto oon twin dcoe 40's but need to do 2 things:-
1)make up the throttle cables
has anybody done this....what did you use?
2)fix the 2 cables to the accellerator pedal
how have people done this?
many thanks ............again
aaron
austin man
posted on 4/10/10 at 09:51 PM |
I used bike cables with no problems, attached them to the pedal with a bolt drilled through and clamped with bols and washers no problems in 6k of
hard driving
posted on 5/10/10 at 08:43 AM |
Only one throttle cable required ----- 2 will only cause problems.
Make sure you have a stop on the pedal to ensure the throttlle can only be opened to about 98% of carb spindle movement, any more will cause damaged
carbs and/or broken throttle cables.
