Author: Subject: Can you pass IVA with a boot Tonneau fitted?
franky
posted on 15/10/10 at 05:42 AM Reply With Quote
As above, is it possible to pass an IVA with a tonneau fitted over the boot? Its not there to hide anything in the boot area that wouldn't pass.
simonwinn
posted on 15/10/10 at 06:05 AM Reply With Quote
Probably not as the fasteners used may not meet the radius test. I was advised to leave all weather gear until after the test. This was mainly down to press studs on the screen frame though, it could be different for things at the rear. I'm sure someone will come along with a deffinate answer.....
snapper
posted on 15/10/10 at 06:32 AM Reply With Quote
Can you pass IVA with boot tonneau
YES
Gavic C has
Fuel filler should not be covered by it
I eat to survive
I drink to forget
gavin174
posted on 15/10/10 at 06:52 AM Reply With Quote
sorry Paul my fuel filler IS covered by tonneau...
for the reason that fuel is not allowed to be able to spill into passenger compartment.
I had to remove the tonneau enough for the tester to see the filler cap,but that was all
[Edited on 15/10/10 by gavin174]
posted on 15/10/10 at 06:55 AM Reply With Quote
Well Caterham have done it for the past 30-odd years!
It's Evolution Baby!
speedyxjs
posted on 15/10/10 at 07:06 AM Reply With Quote
I was going to cover mine with a tonneau but velcro'd on (unless that would be an IVA failure in which case who suggested that stupid idea?).
interestedparty
posted on 15/10/10 at 07:34 AM Reply With Quote
I was under the impression that luggage compartments needed a lockable cover. If that's true then maybe it depends on whether there is actually a boot under the tonneau or if it's just an open area?
mad4x4
posted on 15/10/10 at 08:28 AM Reply With Quote
I failed on the SVA as the cover was "Soft" got told to put Wood under it and it would be OK
Scot's do it better in Kilts.
franky
I know you don't need a lockable area. Also my filler is in the rear panel with the hose boxed around in the boot where it bends from the filler to the rear panel.
Cheers for the advise
Alan M
posted on 15/10/10 at 08:45 AM Reply With Quote
I passed SVA with a tonneau cover, fixed with press studs and with the fuel filler underneath the cover
Richard Quinn
posted on 15/10/10 at 12:22 PM Reply With Quote
Ditto. My filler cap also just screws on and when I asked my SVA tester about it needing to be lockable he told me that the wording was "secure" and to him that meant "won't fall off".
The more I think about it, the nicer my tester was!
Blackbird Rush
posted on 15/10/10 at 02:51 PM Reply With Quote
Mine passd IVA with no issues (fuel filler no where near this area)
Dangle_kt
posted on 15/10/10 at 03:40 PM Reply With Quote
I passed sva with a boot cover velcro'd on.
