Author: Subject: Slipping clutch...
robbydee
posted on 12/6/04 at 10:07 PM Reply With Quote
Slipping clutch...
Pinto 2.0 with twin 40`s and i find the clutch only slips when changing from 3rd to 4th?? perfect from a standing start ie 1st to 2nd and 3rd but slips when 4th..
suggestions?? just the plate ? bearing ? or the whole lot? if so what you lot running?
once again pinto 2.0 carb type 9
posted on 13/6/04 at 06:30 AM Reply With Quote
First check the clutch fork is clearing OK otherwise - new clutch required.
