New Topic New Reply
Author: Subject: Roll Cage
alawrence
posted on 17/10/10 at 10:53 AM Reply With Quote
Roll Cage
ok...after all that
Is there anyone with a design for a compliant roll cage that can be bolted/welded to a completed chassis ?
[Edited on 17/10/10 by alawrence]
lewis
posted on 17/10/10 at 03:09 PM Reply With Quote
This is what I will be looking into over the winter too,I think welderman sells them...well I hope he still does might be worth sending him a msg,let me know if you sort something else.
lewis
posted on 17/10/10 at 03:10 PM Reply With Quote
mark chandler
posted on 17/10/10 at 04:51 PM Reply With Quote
The design is in the MSA blue book, as long as you follow this to the letter you will be okay.
gavin174
posted on 17/10/10 at 05:15 PM Reply With Quote
I havent had much luck understanding the blue book..
it says the front legs must be straight and then pic 3 & 4 have bends in them..
this is what i want..
front hoop straight at the bottom and then a small kick backwards..
and bend in the roof bars for better access... is this allowed
[Edited on 17/10/10 by gavin174]
alawrence
posted on 17/10/10 at 06:04 PM Reply With Quote
i know its got to be to the book
but im not going to be mking it and im not to concerned about the detail...
i just want one ........
welderman
posted on 17/10/10 at 07:20 PM Reply With Quote
i will be having a clear out soon, will shufty through all the bits of cages ive got
lewis
posted on 17/10/10 at 07:33 PM Reply With Quote
Weldeman are you still making cages? I have a Indy with a hoop no rear struts and would like a full cage like the MK one does not have to be to the blue book regs do you sell them in kits to weld/bolt in?
welderman
posted on 17/10/10 at 07:36 PM Reply With Quote
yes, have some left if your not bothered about the regs mate, can make it weld in of bolted to your spec
Joe
lewis
posted on 17/10/10 at 07:45 PM Reply With Quote
cool! ill be intouch when i know what i want any idea of prices for what i have decribed pls.
New Topic New Reply
