Author: Subject: Which rivnut tool?
Thinking about it
posted on 17/10/10 at 07:00 PM Reply With Quote
Which rivnut tool?
Any recommendations on a riv nut tool?
4mm-8mm THREADED RIVNUT RIVET NUT INSERT SETTING TOOL on eBay (end time 12-Dec-10 10:44:20 GMT)
Or pay the extra for something like this.
link
And another option.
link
[Edited on 17/10/10 by Thinking about it]
austin man
posted on 17/10/10 at 07:03 PM Reply With Quote
I managed to break 2 of the first type it was okay for the smaller rivnuts but when used for the larger ones they sprained. May have been too much pressure or nut up to the job not sure.
IanBrace
Builder
Posts 159
Registered 21/5/09
Location Lincoln
Member Is Offline
Photo Archive Go!
Building: Re-built 1986 O and C Sport and sold it! Now a K s
posted on 17/10/10 at 07:06 PM Reply With Quote
I have one similar to the cheap one.. it's great for using smaller sizes and ali inserts but is a real struggle with M8 stainless ones
www.aerialphotography.org.uk
mookaloid
If I was starting a new build I would go for the second one.
If I only had half a dozen or less to do I would get the cheap one
SPYDER
posted on 17/10/10 at 07:28 PM Reply With Quote
We had a demo of the second one at Newark earlier this year.
It was so unbelievably effortless, even with stainless rivnuts, that we suspected he was using extra thin rivnuts.
So we took some of our own stainless 8mm items along the day after only to find that it coped just as easily!
So we bought one.
Recommended.
Geoff.
iank
posted on 17/10/10 at 07:29 PM Reply With Quote
Another option
http://www.lathyrus.eu/
Special tools and parts -> Rivnut setting tool
Anonymous
handyandy
posted on 17/10/10 at 07:30 PM Reply With Quote
I have the 2nd one, can,t fault it, worth the money in my opinion.
cheers
andy
Werner Van Loock
posted on 17/10/10 at 07:48 PM Reply With Quote
I bought the first one and broke it, should've got the second one.
I repaired my el cheapo by replacing the center pivot with the circlipses on by a bolt.
What happens with the cheap ones is that when you put pressure on that the sides open up and the circlipses bend, a bolt with large thick washers won't budge and keeps the tool in 1 piece, so might do that before breaking it
http://www.clubstylus.be
Lars
posted on 17/10/10 at 07:51 PM Reply With Quote
I used the bolt + steel plate + g-clamp method.
have not had the need to buy a tool (or replace the one that broke on the second nut)
(FYI if you are not familiar with the method, drill a hole in the steel plate, insert bolt and screw rivnut onto the other side. Then insert the rivnut where you want it to go and use the g-clamp to hold it down, then just tighten the bolt and the rivnut is installed.
I used this only with ali rivnuts not sure how steel one will cope)
interestedparty
posted on 17/10/10 at 09:18 PM Reply With Quote
That sounds interesting but I'm not quite seeing in my head, and chance of a sketch?
iank
posted on 17/10/10 at 09:24 PM Reply With Quote
Something like this
http://www.fjr1300.info/howto/rivnut-tool.html
Anonymous
AdamR
posted on 17/10/10 at 09:42 PM Reply With Quote
I've got the 3rd type. Very robust & easy to use. Looks like it's a bit more compact that the 2nd type also.
Canada EH!
posted on 18/10/10 at 01:24 AM Reply With Quote
I have a large, one like # 1, but the # 3 gets very handy expecially when working on the driveshaft tunnel. I had to destroy the 31 type one when after incerting the rivnut there wasn't enough room to remove it.
DaveFJ
posted on 18/10/10 at 08:31 AM Reply With Quote
I bought one of these...
linky
cost me £55 from a show but never regretted the expense.. a superb tool and excellent for setting tougher rivets as well...
only drawback is it is a bit large so you cant always get into those small places...
Dave
40inches
posted on 18/10/10 at 09:56 AM Reply With Quote
I have one of RIVNUT/NUTSERT SETTING TOOL SILVERLINE M4, M5, M6 & M8 on eBay (end time 26-Oct-10 18:55:56 BST) for about 12 months, pulls 8mm steel rivnuts easily,and has had plenty of use
posted on 18/10/10 at 11:12 AM Reply With Quote
I did something similar when I had a small number of M8 steel rivnuts to set (didn't warrant buying a tool as there were so few to do).
I would recommend a good smear of grease on the bolt, and a few greasy washers under the nut, to help things along. Don't expect the bolt to last too long either, as it takes a fair bit of force.
