Author: Subject: ZETEC Inlet, TBS, ECU???
i_froloshki
posted on 18/10/10 at 08:55 AM Reply With Quote
Hi folks, i try to find the answers with the search tool but i couldn't so here is my problem. I am building a LHD DAX RUSH. I have a 95 silver top engine and MT75 gearbox. Obviously the inlet manifold cannot be used with this car so i need to know what options do i have.
1. Custom manifold with TBS with MS - it is something that i know will work but is is not locost at all.
2. ST170 manifold which is very hard to find here, TBS and MS.
For these i know. So - the questions: can i use the ECU and injectors that i have from the mondeo with the loom? What kind of TBs to use? I know that in this forum i can count on you so waiting for your help.
I also have a problem with the gear stick position. I extended it yesterday as it is recomended for my car, butr now with the original stick it hits my steering wheel when i pit it on 1st gear (LHD remember). It is not a big wheel - 32cm diameter, but probably the stick it too big If i cut it, how can i make the pull-up button for reverce gear, or just to remove it? Thanks in advance for your help.
Best regards
Yavor
whitestu
posted on 18/10/10 at 09:27 AM Reply With Quote
Bike carbs and Megajolt are probably the cheapest option depending on what kind of emmissions test you need to pass.
Stu
femster87
posted on 18/10/10 at 09:31 AM Reply With Quote
i am currently fabricating a plenum chamber to run the standard injector rail and use the ECU from the mondeo. I got help from a member on this forum called big-wasa. he has it running on his car and it sounds perfect
big-vee-twin
posted on 18/10/10 at 09:32 AM Reply With Quote
I initially whent this way and then changed to Duratec.
ST170 manifold with GSXR 750 throttle bodies, I used the ST170 injectors too, you will also need a new fuel rail to suit.
The throttle bodies will need respacing and the injector pockets on the ITB needs blocking because the ST170 manifold has its own injector ports. Unless you want to run twin injectors - Megasquirt would be the ECU option or if youve got a bit more cash something like Emerald.
http://www.triangleltd.com
i_froloshki
posted on 18/10/10 at 11:06 AM Reply With Quote
Hi, can you send me some details or drawings or pictures? I will ask big-wasa as well, i saw his pictures. Is there a difference between bike carbs and trottle bodies? I am not after much power of the car in the beginning, more prefer reliability.
will121
posted on 18/10/10 at 11:19 AM Reply With Quote
ive done it (but on a fiesta) by fitting GSXR600 throttle bodies, keeping the orignal fuel rail just by making a fibreglass plenum to enable use of the MAF air flow sensor, worked ok and ended up with 150bhp and reved lot free'er will try get some photo's up later
[Edited on 18/10/10 by will121]
big_wasa
posted on 18/10/10 at 04:23 PM Reply With Quote
re your gear extension there was a post yesterday.
link
As for ecu it ran the engine well in the donor so it can do the same in your kit. Bet its never been done in a Dax though
95 over here would be a 60 pin eec-1v with the pats immobilizer.
As long as you have the key that goes with the ecu then its doable.
There are no instructions as the pin wiring varies from model, spec and year.
Manifold, keep it simple and use your throttle body from the donor along with all the sensors inc idle controle valve.
first start up on efi
first drive
drawings of manifold mine is bassed on
make life easy and start with one of zetec bike carb inlet manifold flange on eBay (end time 18-Oct-10 19:26:02 BST)
AdrianH
posted on 18/10/10 at 07:34 PM Reply With Quote
Wasa like the original poster also wondering about using a zetec in next build..
If using injection with the plenum chamber how have you fastened the injectors, is there a sandwich plate I need to look out for?
I have bare engine at the moment no inlet or exhaust manifolds fitted.
It looks as though one can pick up escort inlet manifolds complete quite cheep, but all seem to be plastic!!
Using the plate on ebay as shown can they be drilled or machined for the injectors?
Sorry for hijacking the post but of great interest.
Adrian
Why do I have to make the tools to finish the job? More time then money.
will121
posted on 18/10/10 at 08:27 PM Reply With Quote
Originally posted by AdrianH
If using injection with the plenum chamber how have you fastened the injectors, is there a sandwich plate I need to look out for? Adrian
you can use the early fiesta or 1800 escort zetec injector sandwich plate as shown it top picture but then the stardard manifold plate from ebay will not fit but you can get them made up.
i done a guide on another web site about making one here
big_wasa
posted on 18/10/10 at 08:37 PM Reply With Quote
I will have to take some pictures.
there are injector bungs turned up and welded into the flange and runners at the same angle as the plastic one.
The early fiesta/escorts with an alluminium manifold had a seperate plate with the injectors and rail allready mounted.
FORD ESCORT INLET MANIFOLD on eBay (end time 19-Oct-10 14:57:22 BST)
AdrianH
posted on 18/10/10 at 08:43 PM Reply With Quote
Ok magic, would this have it?
Escort M reg inlet manifold injectors etc - breaking on eBay (end time 18-Oct-10 22:13:30 BST)
Adrian
big_wasa
posted on 18/10/10 at 09:23 PM Reply With Quote
yeh
AdrianH
posted on 18/10/10 at 09:28 PM Reply With Quote
Thanks again, bought it and will await delivery, long term next project.
Adrian
will121
posted on 19/10/10 at 06:31 AM Reply With Quote
the ebay ones looks like might be a 1600cc one from the size of the throttle body, the sandwich plate ports are a little bit smaller than the 1800 one but not much and if fitting ITB's shouldnt an issue, just need to fit the 2litre side feed injectors so all injection items match the ECU
big_wasa
posted on 19/10/10 at 06:46 PM Reply With Quote
As above but there will be plenty of metal to give it a bit of a porting.
Ports only need to be as big as the head. If your using the whole thing then a 2l Tb bolts directly on.
