Bluemoon
| posted on 27/10/10 at 10:12 AM |
Feista Endura E starter problems
Hi all,
Starter motor on our Festia (Endura E engine) has started to play up, spins but will not allways engage with the flyweel (complete with the nasty
teeth on teeth noise)..
Replaced starter with a recon unit. Still does it.. Any ideas (will take the replacement starter back in case it's also faulty), is this a known
issue?
Ta
Dan
marcjagman
| posted on 27/10/10 at 10:25 AM |
Could be the ring gear that's damaged.
col
| posted on 27/10/10 at 05:27 PM |
yep probably above or faulty battery connection.
