Author: Subject: OT - central heating again....
chrsgrain
posted on 31/10/10 at 05:51 PM Reply With Quote
Hi all,
Central heating question again.... having changed the pump - the central heating and hot water are still playing up...
Heating works on continuous, but as soon as the hot water is switched on the whole lot stops working, and also the CH doesn't work on timed.
Any ideas??
Ta
Chris
stevebubs
posted on 31/10/10 at 06:27 PM Reply With Quote
what do you mean by "stops working"
It explodes? Presuming not as you're posting
Gas? Electric?
If Gas, Pilot light goes out?
Or just goes back to pilot light?
chrsgrain
posted on 31/10/10 at 06:30 PM Reply With Quote
Ah - yes the first post was a bit lacking in info!
On everything except CH continuous, the boiler comes on full burn for a few seconds, then stops working and goes back to standby (though the pilot light stays on)
Chris
The Baron
posted on 31/10/10 at 08:30 PM Reply With Quote
I recently had a similar issue.
The CH would not come on unless the HW was also on.
Turned out to be the 3 way valve....£130 fitted.
