Author: Subject: zetec alternator mounting
femster87
posted on 1/11/10 at 04:04 PM Reply With Quote
Idea for mounting the alternator on blacktop engine. I really do not want to pay for the kits around, the build cost is mounting up too quickly. So I would appreciate anybody's DIY solution.
cheers
jacko
posted on 1/11/10 at 04:22 PM Reply With Quote
look in dunk3 's photo archive
jacko
big_wasa
posted on 1/11/10 at 04:32 PM Reply With Quote
Its not a big job.
pick an alternator and some 6mm plate. Stick a couple of lugs on it and wedge it under the inlet.
Ive done four home made ones and just use what ever is cheap at the time with a multi v pulley.
I think this one was a R5
[img][/img]
posted on 1/11/10 at 04:33 PM Reply With Quote
First attempt for the 1.8 silvertop....
Have you got the air con pump bracket off the blacktop? I simply modified mine to make a slimmer bracket for the alternator.
Hope that inspires you, cost me nought but a bit time and a new belt
femster87
posted on 1/11/10 at 04:38 PM Reply With Quote
yes i still have the bracket. thanks alot guys would have a go this weekend.
thanks
RichardK
posted on 1/11/10 at 07:04 PM Reply With Quote
My attempt! In the end wanted to use my pinto alt
In this picture it shows the adjuster which is why I wanted the concave/convex washers the other day (still do m8), because the angle changes of the threaded rod when its wound in and out, hence why the washer is a better solution but I'm buggered if I'm paying 13 for a pair of washers!
Cheers Rich
[Edited on 1/11/10 by RichardK]
Gallery updated 11/01/2011
lotusmadandy
posted on 1/11/10 at 08:44 PM Reply With Quote
Bloody hell Rich,
You must put a lot of time and effort
into the swag you make.
I'm very impressed mate
Big Stu
posted on 3/11/10 at 08:33 PM Reply With Quote
Not the neatest job in the world but it works.
Altenator
Altenator
View User's Profile E-Mail User View All Posts By User U2U Member This User Has MSN Messenger
RichardK
posted on 4/11/10 at 09:44 PM Reply With Quote
Very clever mate, didn't even think of using the alt as an idler pulley.
Nice work!
Rich
