Author: Subject: Big clear out
flak monkey
posted on 7/11/10 at 05:31 PM Reply With Quote
Big clear out
More stuff to go, prices include post.
1
1
From top left-
Narrow band lambda sensor, 4wire. £10
Sticky backed reflectors £5
Phormula interface cable £10
Mintex powerlite Smart brake pads. Used but hardly any wear. £10
Type 9 input shaft, used for clutch alignment £10
NGK BR7EFS spark plugs. Brand new, 1 step colder than standard for Duratec £10
Large LCB sticker. £8
Mk1 MR2 headlight retractor relay
Side repeaters - stick on with mini timer connection £10
T9 plastic gear lever saddle £5
Rotrex pulley, 90mm. £45
Duratec crank pulley £15
Noise filters for megasquirt £5 each
Megasquirt air temp sensor and bracket £10
New Duratec crank position sensor and alignment tool £25
VA recirculating valve £7
Duratec water temp sensor connector £5
Oil filter and EGR gaskets for duratec £5
2
2
Black exhaust wrap - few metres, and 3 stainless ties £7.50
Various rubber covers £SOLD
Packet of various sized nut covers £SOLD
1 new poly bush £5
Std pinto alternator pulley, key, nut etc (in bag) £7.50
Gasket (not sure what its for)
Pinto manifold water outlet connector £5
Zetec etc coil connector £5
M14 track rod end lock nuts (escort and sierra rack) £4
Brake liht test switch £5
Change over switch £4
On-Off-On switch £4
New Cortina hub dust caps (no longer avail from Ford) £15
Type 9 to pinto support bracket £7.50
8 1/2" longer wheel studs (ford) £12.50
ECU comms lead (suit MS, Omex etc etc) £7.50
[Edited on 7/11/10 by flak monkey]
Sera
http://www.motosera.com
gavin174
posted on 7/11/10 at 05:36 PM Reply With Quote
input shaft for me please....
please let me know payment details
adrianreeve
posted on 7/11/10 at 05:55 PM Reply With Quote
You have u2u ref the air temp sensor and comms cable!
Adrian
[Edited on 7/11/10 by adrianreeve]
marcjagman
posted on 7/11/10 at 05:56 PM Reply With Quote
All the rubber and nut covers please.
daniel mason
posted on 7/11/10 at 06:46 PM Reply With Quote
how much exhaust wrap is there? will there be enough to do the 4 headers inside the engine bay?
flak monkey
posted on 7/11/10 at 06:49 PM Reply With Quote
No idea, 2-3 metres I guess.
Sera
hobbsy
posted on 7/11/10 at 08:16 PM Reply With Quote
U2U re brake pads
g60_edge
posted on 7/11/10 at 10:36 PM Reply With Quote
I'll take the wheel studs please. u2u coming your way.
flak monkey
posted on 10/11/10 at 07:50 PM Reply With Quote
Bump
Studs, pads, serial lead, temp sensor, and covers sold. Everything else available.
Sera
scudderfish
posted on 10/11/10 at 08:07 PM Reply With Quote
I'll have the pair of MS noise filters please.
gavin174
posted on 10/11/10 at 09:44 PM Reply With Quote
did you receive payment for the input shaft?
flak monkey
posted on 11/11/10 at 04:07 PM Reply With Quote
Yes.
Those people who have paid for stuff, it will get sent tomorrow.
Sera
flak monkey
posted on 20/11/10 at 06:15 PM Reply With Quote
Bump
Sera
Raymond Y
posted on 21/11/10 at 04:28 PM Reply With Quote
I will take the Zetec etc coil connector if still available. You have U2U.
Raymond
