jeffw
posted on 11/11/10 at 10:39 PM |
Zetec on the Rollers
This is the result from the last session at ATspeed where the cams where swung for maximum power.
The figures are as measured at the wheels. Interesting comparison with moving the vernier pulleys
oadamo
posted on 12/11/10 at 07:43 AM |
engine spec ? thats some good numbers.
adam
jeffw
posted on 12/11/10 at 09:21 AM |
Omex 600
Jenvey DCOE TBs
New blacktop
CNC Heads Port and polished large valve head
CNC Heads cams (they are somewhere beyond fast road and below rally)
Bottom end is stock (arp bolts)
Standard pistons
The thing holding it back now is the exhaust so I plan to get Powerspeed to do a 4-2-1 exhaust for it. Hopefully we will see 175-180 at the wheels at
that point. The head will flow enough air to make 250-260 at the cranks so the next step would be rods and high comp pistons.
adithorp
posted on 12/11/10 at 09:59 AM |
Good job I'm upgrading from the look of those numbers
http://jpsc.org.uk/forum/
jeffw
posted on 12/11/10 at 11:42 AM |
You have no problem Adi....your car must be 200Kg less than mine
will121
posted on 12/11/10 at 11:52 AM |
thats a good result, only problem is im thinking i want more now
posted on 12/11/10 at 11:55 AM |
How much did that lot cost you? I'd be well disappointed with that for the engine spec there.
adithorp
posted on 12/11/10 at 01:24 PM |
Just an honest set of rollers rather than a set calibrated to flatter.
jeffw
posted on 12/11/10 at 01:28 PM |
It is at the wheels remember....
atspeed racing
posted on 13/11/10 at 10:16 AM |
Thank you.
Good comment. ![](/images//smilies/bigsmile.gif)
jeffw
posted on 13/11/10 at 12:22 PM |
It drives really nicely, almost turbo like at 3.7K rpm. It is a credit to the guys at Atspeed. Once I have the 4-2-1 exhaust done it will be going
back to Atspeed for another tweek and hopefully more than 170 at the wheels.
The car is seriously quick now.
