daniel mason
posted on 15/11/10 at 10:35 PM |
what do i need and where to buy oil filter relocation kit?
am needing to move the oil filter in the mnr as the steering arm runs close to the side of the engine. where is the best place to buy one and what
exactly do i need? will i need a seperate oil cooler?
i have found a mocal one on ebay from seller matty zx but it says for use with honda engines up to 2.0 litre and was not sure if it would be ok for
the f20c?
austin man
posted on 15/11/10 at 10:46 PM |
cant you fit a smaller filter I fitted an Alpha Romeo one to my Zetec will probabley have to change it more often but it clears the steering
daniel mason
posted on 15/11/10 at 10:51 PM |
its about 35mm away from oil filter backing plate! is would need to be tiny.
Charlie_Zetec
posted on 15/11/10 at 10:54 PM |
If you're just relocating the filter, you'll need a take-off plate and cover, plus the remote housing, some unions to suit, suitable pipe
and clamps to accompany.... I got all my bits from Merlin Motorsport, although I also incorporated an oil cooler, relocation housing, and
thermostatic valve for my zetec install!
alawrence
posted on 15/11/10 at 10:55 PM |
REMOTE OIL FILTER HEAD WESTFIELD CATERHAM 7 DAX LOCOST on eBay (end time 12-Dec-10 11:01:59 GMT) 0
daniel mason
posted on 15/11/10 at 10:59 PM |
am no good at links but the link alawrence put up is from the same seller as the complete kit which i saw. it came with hoses,take off plate and
filter housing
INDY BIRD
posted on 15/11/10 at 11:01 PM |
try think automotive they do them i got one for my zx14
http://www.thinkauto.com/index.html
MK9R
posted on 16/11/10 at 07:57 AM |
+1
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
