Author: Subject: extra efi ecu megasquirt
alawrence
posted on 19/11/10 at 06:33 PM Reply With Quote
anyone any experience of the above ecu and company ?
MikeR
posted on 19/11/10 at 06:39 PM Reply With Quote
if i'm right, daxtojero (or something similar) is the bloke who runs the web site / company.
He did some early development on the megasquirt, then branched the internal code to create megasquirt'n'extra. This added extra features and became very popular.
Never delt with him, but he is an authorised reseller of the system (so has some backup from the community that the product is to a certain standard).
I'm tempted with the microsquirt from trigger wheels when i go efi (in about 5 years at my rate of progress) - seems cheaper for a well packaged product that does almost the same. But im struggling to see what i'll be missing if i do go that way.
rpm
posted on 19/11/10 at 07:05 PM Reply With Quote
got my ms1 extra unit from him, he was very helpful and patient via email when i had problems setting it up and even took it back, checked the unit did a small fix and returned it free of charge. so i'd reccomend him
expert
ex= a has been
spurt= a drip under pressure
scudderfish
posted on 19/11/10 at 07:06 PM Reply With Quote
Top product, top bloke.
SPYDER
posted on 19/11/10 at 07:20 PM Reply With Quote
I bought my Megasquirt V3 ECU from ExtraEfi a few years ago having been strung along by another supplier for weeks and weeks.
I needed a V3 with four ignition outputs to suit my COP setup. They made one up in double quick time and it came with the necessary software ready loaded including a base map to get me started. They fitted an extra external connector to suit the extra wiring required.
My setup triggers from a 24-1 camshaft position sensor which is quite unusual. The manual was clear enough for me to understand and I was able to get up and running with only one phonecall to ExtraEfi.
I have recently added a wideband Lambda sensor. This was easily incorporated into the ECU software using a laptop.
This is possibly the main advantage of Megasquirt. It is user programmable.
But some would say not always user friendly.
I can't really comment on how it compares to OMEX, DTA, Emerald, etc. They are often said to be superior in some respects.
I can only recommend the Megasquirt V3 and ExtraEfi based on my own experience.
I'm sure that whichever ECU you plump for there will be a local locoster willing to help.
Where are you based?
Can I just say that I have no connection with ExtraEfi.
Geoff.
alawrence
posted on 19/11/10 at 07:27 PM Reply With Quote
im in staffs
i havnt sorted ecu yet and looking at options..
i will have gsxr 600 tb on a st170 manifold zetec 2.0
i have an omex manifold (see ic in archive) im going to sell
ps: a great response from the post all....
SPYDER
posted on 19/11/10 at 07:41 PM Reply With Quote
Are you going to use the Zetec coil packs and EDIS unit?
alawrence
posted on 19/11/10 at 09:17 PM Reply With Quote
i dont know...whats edis unit
matt_gsxr
posted on 19/11/10 at 09:26 PM Reply With Quote
the diy extra guy is what you want in a one man outfit. Patient and helpful.
Not as cheap as the DIY option, but a worthwhile investment unless you like electrons.
Matt
scudderfish
posted on 19/11/10 at 09:28 PM Reply With Quote
http://www.autosportlabs.net/Ford_EDIS_technical_information
It is the Ford way of running a coil pack to spark the plugs. MS can use it, and it means your not connecting coilpacks directly to your MS (which can let the magic smoke out if you get it wrong)
