The Baron
posted on 25/11/10 at 04:28 PM |
ESC ignition Module
I am having a senior moment, on the ESC ignition module, is the plastic tube outlet, for vacuum advance from the carb?
B
Davedew
posted on 25/11/10 at 04:53 PM |
If you are talking about the ESC in a sierra, then you should have a tube that connects to it from the inlet manifold. It is a built in MAP sensor for
sensing engine load & adjusting the advance & retard of the timing.
big_wasa
posted on 25/11/10 at 06:05 PM |
yep.
The Baron
posted on 26/11/10 at 08:25 AM |
ta ![](/images//smilies/smile.gif)
