rich201283
| posted on 29/11/10 at 06:10 PM |
Rollbar trim????????
I hav had to cut some square holes trough my fibreglass tub to mount the rollbar to the chassis, Does anyone know of some trim that i can put round
the the rollbar the seal the hole?
blakep82
| posted on 29/11/10 at 06:14 PM |
sikaflex or silicome?
or rubber u trim round the hole
________________________
StevieB
| posted on 29/11/10 at 06:28 PM |
Maybe have a look at some motocross sites - a common addition to most bikes is a neoprene seal around the forks to keep the muck out.
Try kriega - I know they do the seals, but I'm not sure of the sizes and whether it'll fit a roll bar
Howlor
| posted on 29/11/10 at 07:55 PM |
Maybe some 40mm waste pipe covers from the plumbing section of B&Q sprayed up to match the car colour?
norfolkluego
| posted on 30/11/10 at 12:21 AM |
Cut oversized rubber grommet (do they do them that big)
gazzarose
| posted on 30/11/10 at 08:18 AM |
Have a try of a Witches Hat Cable Grommet Boat Steering Marine Cables on eBay (end time 13-Dec-10 08:32:04 GMT) . I use them
in work when I fit outboard engines to boats. You can get them in a few different sizes. Use the type with the ring like in the link so you can screw
them down, there are a type that just pops into the hole but I don't like them and they probably wouldn't suit a square hole.
Gareth
