Author: Subject: Torque Wrench - Cost/Quality and Torque Range?
dhutch
posted on 5/12/10 at 12:10 PM Reply With Quote
I need a torque wrench, and Christmas is coming. Simples.
We not really, because having never had one, ive never really looked at values, just use my intuition based on the material, bolt size and application. So when i look at what i want to send a link to some one to buy it for me theres a whole load of ranges 25-50 40-80 100-250 and im left cold as to which i want to best cover working on the car.
I spanner on the tintop for most things that need doing, also the kitcar, but also am looking to do some engine building soon.
IM also due a socket set, which is on the list too, and for that im planning to go 3/8inch so would pick the same for the Torque Wrench i expect although i could use an adapter. Assuming people wouldn't go 1/2in on the socket set?
Daniel
blakep82
posted on 5/12/10 at 12:16 PM Reply With Quote
i'd always go 1/2 inch drive on socket sets
________________________
mookaloid
posted on 5/12/10 at 12:20 PM Reply With Quote
For car engines you will mostly use 1/2" drive sockets and torque wrench.
Having said that I wouldn't want to be with out my 3/8" drive set and a 1/2" to 3/8" converter to use the torque wrench with the 3/8" sockets.
3/8" drive torque wrenches are mainly for bike engines.
So in summary get both 3/8" and 1/2" drive socket sets and a 1/2" drive torque wrench
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 5/12/10 at 12:22 PM Reply With Quote
I'd also go bigger.
For engine building it would be best to buy one that has been calibrated. I got quite a reasonably priced one which was calibrated, and inc in the price you could send it back after a year to be checked/adjusted.
jacko
posted on 5/12/10 at 12:30 PM Reply With Quote
Remember which ever you get always slacken off the spring after use or it will be ruined the next time you want to use it
guess how i know
And as above go with the 1/2 ins drive
Good advice from mookaloid about the 3/8 sockets
Jacko
designer
posted on 5/12/10 at 12:33 PM Reply With Quote
Have a look at what torque range you will be using, then buy a wrench with your required range in the middle.
posted on 5/12/10 at 12:41 PM Reply With Quote
You need a minimum two torque wrenches.
For most engine work on modern cars a 3/8" drive for up to about 25NM ----- most needed for first stage torquing of angular tightened head bolts.
For bigger stuff a 1/2" drive to cover from about 28NM to roughly 200NM
You don't need to pay the earth for a decent torque wrench, you will find them from £11 to £250 upwards.
Just do Google Shopping search on " Torque wrench 1/2" and "Torque wrench 3/8" will turn up Sealey and Draper products for under £30, yo may want to add a third wrench for better coverage in the 10 to 80 NM range.
will121
posted on 5/12/10 at 12:43 PM Reply With Quote
i got a 3/8" drive one last christmas with range of 20-80 lb/ft which suited my zetec rebuild, one advantage or could be disadvantage of 3/8" ones is they are significantly shorter with less leverage at about 11" long which helped me as engine was still in car and using one 18"+ long laying under car doing big end bolts may have been harder, also most head bolts are stretch bolts with angle of turn rather than high torque.
finally worth putting in letter to santa about specialist internal/external star type sockets if required for your engine
Mix
posted on 5/12/10 at 01:25 PM Reply With Quote
Hi
At the risk of bucking the trend
I would suggest you buy 3/8" socket sets and torque wrenches for engine building, (and for the majority of other vehicle work). You will find the additional access afforded by the smaller tooling invaluable and providing you buy reasonable quality tools you shouldn't suffer breakages.
I have the full range of socket sets up to 1/2" and additional part ranges to 1" due to my occupation but it is very rarely that I use anything above 3/8" drive when performing vehicle maintenance.
Have a look in a Haynes manual for the torques you will need to apply - probably only the head bolts will tax a 3/8" drive.
Regards Mick
tomgregory2000
posted on 5/12/10 at 01:26 PM Reply With Quote
Best torque wrench i have ever bought and have is a second hand Snap on digital 3/8, it covers torque ranges from 6.7nm to 135nm so covers most aplications .
Cost about £130 second hand but worth every penny
tomgregory2000
posted on 5/12/10 at 01:32 PM Reply With Quote
Originally posted by Mix
Hi
Regards Mick
Agree 200%
UNLESS you have a landrover Which i now do and i had to buy a 3/4 socket set to cope with the bolts on that
dhutch
posted on 5/12/10 at 02:24 PM Reply With Quote
Edit
Over written the post by mashing the mouse clicking. Sorry!
[Edited on 6/12/2010 by dhutch]
Mix
posted on 5/12/10 at 03:05 PM Reply With Quote
Hi
With regard to callibration - if the means of callibration aren't callibrated themselves then you are p-ing into wind. However you have to ask how accurate you wish to be.
Callibration can be easily achieved using a 'known' mass, (bag of sugar etc.), hung from a suitable tube sleeved over the torque wrench to provide the moment arm.
To be honest, I wouldn't get too hung up about wrench callibration - in most cases the aim is to get a consistent torque across the joint, using a reasonably good quality 'break back' torque wrench will achieve this.
Regards Mick
big_wasa
posted on 5/12/10 at 04:20 PM Reply With Quote
For most stuff I would also go for 3/8" I use it ten times more than my 1/2" Allways buy the best you can and buy once.
posted on 5/12/10 at 04:50 PM Reply With Quote
I have a 3/8" drive that only goes up to 50 lb ft and a 1/2" for the rest but the last cylinder head I did only needed the initial low torque setting then the rest was done using an angle gauge.
SeaBass
posted on 5/12/10 at 06:07 PM Reply With Quote
I've got a very decent Norbar 3/8" which goes up to about 50N.m and a cheaper Draper Expert which ends at about 240Nm.
I'm more concerned about the lower torques for engine parts etc. They get extensive use and I'm getting more anal about correct values.
Stott
posted on 5/12/10 at 08:06 PM Reply With Quote
Hi
Regards Mick
Agree 200%
Agree 300%
I never reach for anything other than 3/8 stuff unless it's going on a gun or breaker bar.
When I was working as a mechanic it was the same even though I was a tech at a L Rover main dealer rebuilding the things every day. Only some of the chassis bolts and head bolts or the wheels/hubs brought out the 1/2" sockets, 3/8 on everything else.
I don't know 1 professional mechanic with a proper complete set of 1/2" shallow and deep sockets. Every single one I know however does have a full set of 3/8", deep, shallow, spline, e torx, torx, crow foot, etc etc etc.
As for the torque wrench debate I use the halfords/sykes pickavant ones. One 8-60 and one 60-300 negating the need for the mid range one. The smaller is 3/8" and the larger is 1/2" which I mainly use with an impact reducer on 3/8" sockets. I think they are fantastic for the money especially on a trade card.
HTH
Stott
dhutch
posted on 6/12/10 at 10:21 PM Reply With Quote
Looking at something like this then?
Not amazing im sure, but seems popular and of a suitable torque range?
http://www.tooled-up.com/Product.asp?PID=15609
Daniel
Stott
posted on 7/12/10 at 09:44 AM Reply With Quote
Yeah that sort of thing but you will still need a bigger one for head bolts or wheel nuts etc.
Stott
