Author: Subject: gear change cable
dilley
posted on 6/12/10 at 06:55 PM Reply With Quote
gear change cable
I am trying to find a gear change cable, it has to be 1150mm overall from gear lever to engine lever, where is the best place to order online? what do I need to allow for fittings? I am assuming I will need m6? slightly lost!!!
dinosaurjuice
posted on 6/12/10 at 06:59 PM Reply With Quote
i used these TELEFLEX CABLE LINKY
Fully stainless, M5 threaded rod either end, works a treat.
daryl
posted on 6/12/10 at 07:40 PM Reply With Quote
hi there a used a place called cable tec just rang him told him wot a wanted it seams cany and it had a b&m this snaped but not sure how long it had been on the car it was put on the road in 06 so its probz had a fair civ use in that time till now so should have been ok as new
