Author: Subject: Fuel pipe routing
cps13
posted on 8/12/10 at 10:41 AM Reply With Quote
Fuel pipe routing
Is it ok to route the fuel pipes & brake pipe underneath the car to the rear or do they have to go down the tunnel?
I am building following a Westfield manual which I though to be IVA compliant which says to put them under the car.
Has anyone passed recently with them underneath?
Daddylonglegs
posted on 8/12/10 at 11:07 AM Reply With Quote
Not sure of the legalities of that, but I personally wouldn't be too comfortable with them under the car. After all, there ain't a lot of clearance as it is, and you don't want the nasty roads to deprive you of stopping power
JB
blakep82
posted on 8/12/10 at 11:13 AM Reply With Quote
manual just says they must be secured, and doesn't state anyhthing about the actual routing, so should be fine.
there's a link below to get the manual for free
________________________
cps13
posted on 8/12/10 at 12:51 PM Reply With Quote
thanks for your answers. I did wonder about the safety aspect of it but thought if it was in the Westfield manual it should be ok... may have been my first mistake!!
adithorp
posted on 8/12/10 at 01:16 PM Reply With Quote
Betterin the tunnel but most tin-tops have them underneath so I can't see how it could fail.
http://jpsc.org.uk/forum/
