Author: Subject: K series engine in a Mini
IanBrace
Builder
Posts 159
Registered 21/5/09
Location Lincoln
Member Is Offline
Photo Archive Go!
Building: Re-built 1986 O and C Sport and sold it! Now a K s
posted on 10/12/10 at 08:52 PM Reply With Quote
Has anyone on here fitted a K series engine in a mini and if so what subframe did you use and what were the main problems... (I'm sure there will be many!)
I've a complete engine and box including subframe and all ancilliaries from an MGF waiting to go into a neighbours 1979 mini.. what have I let myself in for now???
www.aerialphotography.org.uk
ken555
posted on 10/12/10 at 08:58 PM Reply With Quote
16V mini Forum link
There are two main paths for frames when fitting these engines to minis, the metro frame or the modified mini frame. There are advantages and disadvantages to both of these and you need to think carefully before choosing which route to take. Firstly choose you final engine/gearbox combination as this can determine which frame you use. Generally using the R65 gearbox allows you to use a modified mini frame and the PG1 require use of the metro frame as it is larger.
[Edited on 10-12-10 by ken555]
Davey D
posted on 10/12/10 at 09:36 PM Reply With Quote
Im going to be fitting a CG13DE engine out of a K11 nissan micra into my mini. I will be modifying my existing subframe to make it fit.
I think that the metro subframe is slightly longer than the mini subframe? Ive never had a good look at a mini fitted with a metro subframe/ K series engine to know what implications this leads to at the front, if you have to mod the front panel, or if you can trim/modify the front of the the subframe to bring the size back down again
posted on 10/12/10 at 09:47 PM Reply With Quote
Modifying a subframe strictly means the car should have an IVA test doesn't it?
Davey D
posted on 10/12/10 at 09:58 PM Reply With Quote
No because it isnt part of the the Monocoque of the car.
There is a lot of chat about this on TheMiniForums.co.uk There is a thread on there where one of the members asked a Vosa inspector about what they can/cant do without having to IVA. If you modify the bulkhead like required with some engine installs, then that should be IVA'd, but if it is just a subframe mod to fit a new engine, then it shouldnt need one
Strontium Dog
posted on 10/12/10 at 10:20 PM Reply With Quote
That's interesting, what if you mod the baulkhead to fit Webbers? Would you need to IVA as the shell has been altered I wonder?!
Davey D
posted on 10/12/10 at 10:27 PM Reply With Quote
Yes that would require an IVA as you are modifying part of the Monocoque. When i fit the micra engine i will be making a custom inlet manifold so that i wont have to modify the bulkhead in any way
posted on 10/12/10 at 10:31 PM Reply With Quote
Seems like a very grey area since it's clearly part of the structure of the car.
I wonder how many people manage to wedge 16v engines and 5 speed boxes into minis without cutting the inner wings
RAYLEE29
posted on 10/12/10 at 10:34 PM Reply With Quote
OK slightly off topic but reading the above suggests that fitting four link boxes or large tunnels or possibly just a set of arches to an escort for example would require an iva???
I read a story where a local guy did a roof chop on a car and vosa took away the v5 till he had it iva,d
surely that would also mean that cars like bike engined minis would need an iva.
so do all modified cars need an iva or is it just significantly modified and who draws the line?
Ray
posted on 10/12/10 at 10:35 PM Reply With Quote
Yes, definately. Few, if any, people bother though.
Andybarbet
posted on 10/12/10 at 10:45 PM Reply With Quote
One of my best chums has been doing this for about a year now, inbetween university study.
He bought a complete new subframe made out of 1" box section which he has fitted his k series into.
He also has a +100mm front end going on but on trial fitting, it looks as though he might not need the +100mm now.
Its a big job but will be well worth it when its running.
Let me know and i will put you onto him - he has a build diary on one of the forums, just cant remember what one off top of my head.
Worth adding that his car is majorly altered throughout, tubbed inner arches, loads of steel removed wherever possible, full cage, rear beam instead of subframe, coil overs, roof cut out and replaced with fibreglass to save a tad more weight etc !!
Good luck if you go for it.
Andybarbet
posted on 10/12/10 at 10:51 PM Reply With Quote
Hopefully heres a recentish picture
His build diary is called 'Project lesbian Rose' and web address is here :
http://www.theminiforum.co.uk/forums/index.php?showtopic=110011&st=120
g.gilo
posted on 10/12/10 at 11:25 PM Reply With Quote
iva
i think some users get a bit exited about iva or not iva? if you go by the letter
surely a pair of sills on a mini or escort or chopping the flitch panels as in previous pics
means an iva. what utter crap .imao. just to get you going, why spoil a mini by fitting a k series?
[Edited on 10/12/10 by g.gilo]
posted on 11/12/10 at 07:09 AM Reply With Quote
Make you realise why in Australia they insist in a qualified engineer overseeing builds.
Andybarbet
posted on 11/12/10 at 09:31 AM Reply With Quote
This one is going through an IVA because my friend wants to make sure it is fully legal etc, so i would assume that if it passes an IVA it should all be ok.
I didnt want to go on about IVA etc as this topic was originally just asking if anyone was doing it or had any info on it.
jimmyjoebob
posted on 11/12/10 at 11:06 AM Reply With Quote
Would a standard mini pass an IVA bearing in mind all the exposed seams and gutters?
If at first you don't succeed, hide all evidence you ever tried!
posted on 11/12/10 at 01:59 PM Reply With Quote
At least the standard Mini was structurally sound.
IanBrace
Builder
Posts 159
Registered 21/5/09
Location Lincoln
Member Is Offline
Photo Archive Go!
posted on 11/12/10 at 02:09 PM Reply With Quote
Yeah the crumple zone is the drivers legs!
