MakeEverything
posted on 13/12/10 at 08:44 AM |
Silly-Con Hose Bends
Hi all,
This morning ive priced up the silicon hoses that i need for the coolant and boost hoses, and am still recovering....
Using one of our suppliers catalogues (I know theyre not the cheapest) as a guide, i thought i'd total it all up;
Coolant
1 length straight 43mm
90 degree - 8
45 degree - 2
Induction
1 length straight 52mm
90 degree - 5
45 degree - 2
= £778.90!
This is on top of the aluminium tube between the bends!
Does anyone have a locost solution at all please? I really cant afford £800 on hoses!
Kindest Regards,
Richard.
RazMan
posted on 13/12/10 at 08:47 AM |
For coolant I used Gates hoses from my local autospares stockist. If you are set on silicone, try ebay and search for Viper hoses or
http://www.viperperformance.co.uk/
[Edited on 13-12-10 by RazMan]
Raz
l0rd
posted on 13/12/10 at 09:01 AM |
What about getting aluminium pipes and then silicone joints.
designer
posted on 13/12/10 at 09:38 AM |
Yes, use aluminium tube for the straights.
Richard Quinn
posted on 13/12/10 at 09:43 AM |
I would guess by the number of bends to the number of straights listed, this is alraedy using aluminium for most of the straights
matt_gsxr
posted on 13/12/10 at 10:23 AM |
look up "intercooler kit" on ebay. The cost effective solution seems to be aluminium around the corners with short silicone joiners. You
would have to do some cutting and put some flares on the end otherwise the boost would blow them off.
£80 for the following sounds like it would get you started.
![](/galpreviews/_JAK0020.jpg) ![intercooler kit](/gallery/_JAK0020.jpg) intercooler kit
If you want to stick with your design then Rally Design have a range of silicone tubing at decent prices.
Chaddy
posted on 13/12/10 at 10:28 AM |
Silly-Con
Hi
I used these for my hoses http://www.auto-performance.co.uk/index.php?cPath=22 , well cheaper than most and free delivery.
Not sure if I have read your requirements right but I get them to £253.60 inc Vat.
Dave
l0rd
posted on 13/12/10 at 10:48 AM |
Unfortunately ebay doesn't have any on the dimensions required
matt_gsxr
posted on 13/12/10 at 11:59 AM |
L0rd, I don't quite understand.
The picture shown is for 2inch or 51mm. Surely this is sufficiently close to 52mm to make no difference.
Just trying to help, maybe I don't understand.
Matt
blakep82
posted on 13/12/10 at 12:06 PM |
yeah, i've found that putting 32mm hose over a 32mm ali pipe usually leaves a little bit of slack. 51mm over 52mm is probably better,
it'll streatch more than enough
i used 'silicone hose world' off of ebay, worked out a lot cheaper than i expected. i added mine up to be over £300 going by rally design
prices. think it came in at less than half that.
[Edited on 13/12/10 by blakep82]
________________________
MakeEverything
posted on 13/12/10 at 12:12 PM |
Thanks for the replies guys.
I can probably make some ali bends like the ones you posted matt, Thanks for the idea.
There are two sizes requred, though i can swage the pipework to stop them from coming off.
All i need then, are the straight bits. Much cheaper! Thanks guys.
Kindest Regards,
Richard.
scudderfish
posted on 13/12/10 at 01:31 PM |
Ali hoses will look better as well (in my opinion)
westy turbo
posted on 13/12/10 at 02:43 PM |
thats 2 expensive!! got everything from siliconhoses.com alloy/hoses
very good prices,and rhey shipped to Greece 2 ![](/images//smilies/smile.gif)
dhutch
posted on 13/12/10 at 05:57 PM |
I bought about a dosen black rubber hose parts for £1 each, which have all cut up into 2/3 suitable lenghts/bends. Job done!
l0rd
posted on 13/12/10 at 08:44 PM |
Matt
My bad
didn't notice as i was looking for the water pipes 43mm.
![](/images//smilies/sad.gif)
MakeEverything
posted on 14/12/10 at 11:25 AM |
To be honest, Rubber would do but i cant find any that will take more than 80 degrees in temperature.
Kindest Regards,
Richard.
scudderfish
posted on 14/12/10 at 11:57 AM |
Really? my thermostat has even opened at 80 degrees.
RazMan
posted on 14/12/10 at 01:05 PM |
That's why the Gates catalogue is so useful - it is listed by diameter and has a little picture of the actual hose. I spent a few minutes
browsing in my local factor and bought my entire cooling system plumbing for about £40. I even got a really wierd shape that I needed to get around a
chassis tube next to the radiator.
Raz
