Sebastian
posted on 13/12/10 at 08:56 PM |
zetec with TB's trouble starting.
My 2.0 zetec with TB's has trouble starting when the engine ran for a while and is hot, but it starts perfect when it's cold!
What can be the problem?
perksy
posted on 13/12/10 at 09:00 PM |
Is your Starter Motor near your Exhaust manifold ?
If it is it could be getting Hot causing the starting problem
Sebastian
posted on 13/12/10 at 09:01 PM |
No the startermotor is on the other side, i have a Silvertop Zetec.
will121
posted on 13/12/10 at 09:03 PM |
what ECU are you running and has it always done it or been ok in past?
snapper
posted on 13/12/10 at 09:06 PM |
Probably the start fuel enrichment making the mixture over rich.
You should have temperature based start enrichment settings set for temperature, if it is the same % throughout the range try reducing enrichment for
higher temp
I eat to survive
I drink to forget
Sebastian
posted on 13/12/10 at 09:11 PM |
I have an older Dunnell system on it, and it started when we had to bring the CO down for the Dutch MOT i was running way to high.
jeffw
posted on 14/12/10 at 06:20 AM |
Looks like you have just answered your own question.
posted on 14/12/10 at 12:36 PM |
Sounds like it simply isn't mapped very well. It was probably running very rich to mask the problems with cold start fuelling.
