tony@signtek.net
posted on 20/12/10 at 08:50 PM |
R1 engine mountings
Can anyone tell me wether i should bolt my engine mounting frame direct to the chassis or should i use rubber between the mounts ??
Any suggestions welcome
adithorp
posted on 20/12/10 at 09:05 PM |
Lots of BECs are solid mounted but it makes them a bit harsh. Mine is mounted via bushes.
http://jpsc.org.uk/forum/
madrallysport
posted on 20/12/10 at 09:20 PM |
Soild mounted my R1 engine to the chassis via its engine cradle.
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
danny keenan
posted on 20/12/10 at 09:34 PM |
its better if its solid mounted.poly bushed tend to brake the weld.
cheers danny
