sippingdiesel
posted on 24/12/10 at 02:18 PM |
can you fit 13" rims on the standard mx5 front hub/upright/brake setup
Hi all im new to the forum and looking to source and clean up all the donar bits over winter for a middy build next year.
After to many hours to admit to using the search button, Ive narrowed the front upright set up to mx5. I have a set of 13" minilites and
revolutions in standard ford PCD and offset.
Will 13" alloys that suit the standard ford fitment go onto mx5 front hubs, and clear the calipers?
Also does anyone know which mx5 hubs are the most suitable as I guess they are not all the same.
Many thanks
marcjagman
posted on 24/12/10 at 02:30 PM |
Isn't the PCD different?
pdm
posted on 24/12/10 at 02:55 PM |
pcd is 100 x 4 on MX5 - people do run 13s on mx though
HTH
RK
posted on 14/1/11 at 06:03 PM |
The answer is yes. I do. I have rota wheels.Ford do not have 4x100.
[Edited on 14/1/11 by RK]
