Author: Subject: 180 degree noodles?
Craigorypeck
posted on 24/12/10 at 08:18 PM Reply With Quote
180 degree noodles?
Can these be got?
Would make routing choke cable a lot easier.
Very tight for space,
Ive seen 90 and 120 jobs.
No 2x90 suggestions!
[Edited on 24/12/10 by Craigorypeck]
avagolen
posted on 24/12/10 at 08:30 PM Reply With Quote
Noodles :- I thought they were for eating.
ReMan
posted on 24/12/10 at 09:04 PM Reply With Quote
http://recipeland.com/recipe/v/Noodle-Surprise-33532?metric=true
scudderfish
posted on 24/12/10 at 09:31 PM Reply With Quote
Two 120s with a bit cut off?
180 degree noodles - that's macaroni, isn't it?
RAYLEE29
posted on 24/12/10 at 09:53 PM Reply With Quote
what on earth are you talking about?
guessing your talking about some kind of cable routing device?
Ray
chrsgrain
posted on 24/12/10 at 10:49 PM Reply With Quote
I think he's declaring that he's a pastafarian....
Chris
Craigorypeck
posted on 24/12/10 at 11:27 PM Reply With Quote
HAHAHA!
Thought car builders knew about these sorts of unconventional thingys!
No worries, santa might bring one, gonna sit up and drink the xmas booze mr tesco left round...
Happy xmas creeps!
RazMan
posted on 25/12/10 at 12:20 AM Reply With Quote
Chris
Excellent
Come to think of it - I could do with one of those for my throttle cable.
Now I know what they are called ........ they are really called that right? I mean, I'm not going to get one of 'those' looks when I ask my local autospares guy for one, am I?
What about a length of brake pipe and some soldering?
*edit* I found some flexible noodles in a bag - do they do pot noodles too?
http://www.rememberdelaware.com/p-84958-jagwire-flexible-brake-noodle-bag-of-10.aspx?gdftrk=gdfV21133_a_7c351_a_7c2656_a_7c84958
[Edited on 25-12-10 by RazMan]
Raz
mangogrooveworkshop
posted on 25/12/10 at 02:00 AM Reply With Quote
Bike shop in Halfords or a real bike shop if theres any left......in the brake spares dept
robocog
posted on 25/12/10 at 10:29 AM Reply With Quote
I used to work in a bike shop in a past life
I'm /sure/ there was a device available that used a pulley that would enable a cable to be routed back on itself and may have been adjustable in angle (I cannot recall whether these were designed for rear deraileur cable routing or for brakes..not that it should matter much apart from it making it more permutations to Google)
I know theres a device called a "travel agent" which is basically a pulley wheel designed for multiplying the cable pull but only seen it in 90 degree
(http://problemsolversbike.com/products/travel_agents)
A pulley wheel and simple fabricated bracket would do what you want, but you would have to keep on top of the oiling (unless you could seal it and keep it packed with grease?)
Alternately bend your own noodle to the required angle
http://velocitynation.com/content/equipment/2010/purdys-rear-derailleur-tweak
Regards
Rob
robocog
posted on 25/12/10 at 10:50 AM Reply With Quote
Rollamajig
I am pretty sure it was this I was thinking of
http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=1802
Not quite 180 degrees but the flex in the bowden (even inf pretty short) would be enough to do the rest surely?
Regards
Rob
indykid
posted on 25/12/10 at 02:54 PM Reply With Quote
bend a 120 round your thumb. the tube's soft enough
