sippingdiesel
posted on 27/12/10 at 06:51 PM |
Cinquecento / Seicento steering rack with sierra or mx5 uprights.
Im looking at building a bec middy single seater (offroad)
the Cinquecento/Seicento stearing rack really lends itself sizewise, but has anyone used this rack with sierra or mx 5 uprights?
I would be interested in understanding which track rods/ends people use with this rack and their uprights.
Many Thanks in advance
NS Dev
posted on 27/12/10 at 07:17 PM |
worst case use rose joints, dont' worry too much, if the rack is the right size and ratio then use it.
l0rd
posted on 27/12/10 at 08:35 PM |
if you are interested i have for sale a set of mx5 uprights and a manual steering rack and some mazda u-joints.
[Edited on 27/12/10 by l0rd]
russbost
posted on 28/12/10 at 11:06 AM |
I use this rack on the Furore, you will certainly need some form of extensions/converters as it is such a short rack (the Fiat track rod ends are
really long!) I get extensions machined with the Fiat thread at the inboard end & Toyota thread at the outboard end as we use the track rod ends
from the donor MR2.
If you are lucky the Fiat TRE's just might be long enough & have the same taper as either Sierra or Mazda steering arm, alternatively, if
the Mazda/Sierra steering arm is the same as Toyota MR2 TRE taper then I could do you a set of suitable extensions from stock.
