Author: Subject: in tank fuel pump with integrated swirl pot
joscorstjens
posted on 27/12/10 at 10:09 PM Reply With Quote
What is the experience with the Webcon WPF096 in tank fuel pump (with integrated swirlpot)?
Does it deliver enough pressure (350 kpa) for an injected pinto?
Do I need to add an additional 'cavity' in the bottom-side of the fuel tank or can I just mount it?
franky
posted on 27/12/10 at 10:22 PM Reply With Quote
It looks like an expensive copy of a e36 bmw fuel pump.... just buy one of these instead....
new..
BMW E36 3 SERIES FUEL PUMP + SENDER UNIT 91>' 183BM0090 on eBay (end time 11-Jan-11 11:56:25 GMT)
Used
BMW E36 M3 3.0 fuel pump 316 318 320 323 328 318is on eBay (end time 06-Jan-11 21:34:31 GMT)
you can buy two as they act like a twin pickup, there's a pipe between the pump and another pickup, so even during fuel surge you'll still get fuel(one either side of the tank). also if you'll still get a stable fuel level reading. buying both used would cost about £45.
Davegtst
posted on 27/12/10 at 10:55 PM Reply With Quote
BMW's usually have their swirl pots as part of the tank. Have a look at a golf or passat pump. These have integrated swirl pots just like the webcon one and can be found very cheaply. How are you planning to mount it though? These type of pumps have a screw on locking ring that screws into a thread on the top of the tank.
MikeR
posted on 27/12/10 at 11:07 PM Reply With Quote
Rover EFI pumps from the mid 90's are nicely integrated and include a fuel level sender.
Chippy
posted on 27/12/10 at 11:24 PM Reply With Quote
I fitted one of these from Ebay, fine if you have the depth to mount it, they are adjustable for height. Feeds my 2.9 V6 so a Pinto would be no problem. The one attached is just an example. Cheers Ray
Fuel Pump & Sender Range Rover vgc PRC9409 & ESR1901 on eBay (end time 22-Jan-11 17:17:05 GMT)
RazMan
posted on 27/12/10 at 11:29 PM Reply With Quote
I fitted one too - 5 years on and still going strong
Raz
