Author: Subject: "trigger" handbrake levers, anyone got one?
tony-devon
posted on 6/1/11 at 12:21 PM Reply With Quote
as per the title, for my build the handbrake is a pain, I either go to great effort to hide it, but then its rarely easy to use, or I need something proper smart
seen these online, just under £100 delivered, but look good
anyone got one, or used one, got any opinions or comments on them, this is a fortune to me, so if Im going to spend it, I need to be sure that its a decent product
I spent less money on the engine carbs, electrics and the sierra rear end all together than this handbrake lever LOL
heavy is good, heavy is reliable, and if it breaks, hit them with it
posted on 6/1/11 at 12:29 PM Reply With Quote
Tony,
There was a discussion recently on fitting hydraulic handbrakes or line lock devices. They tend to be much smaller and easier to place than cable operated ones - probably considerably cheaper than the trigger type you mention as well.
Out of curiosity, is a trike actually required to have a parking brake (I realise it would be hard work wthout one) or is it considered to be a motorbike?
(really showing my lack of bike knowledge, but I assume they have no form of parking brake?)
http://www.locostbuilders.co.uk/viewthread.php?tid=147133
Also just spotted a hydraulic handbrake for sale...
http://www.locostbuilders.co.uk/viewthread.php?tid=148350
alawrence
posted on 6/1/11 at 12:34 PM Reply With Quote
I think scootz has one for sale if its hydraulic you want
check the "for sale" here
blakep82
posted on 6/1/11 at 12:43 PM Reply With Quote
i think by scotts recent post, he's thinking of keeping his hydraulic Hbrake.
as long as a trike doesn't actually need to have a hand brake, i'd go with the 1/4 turn line lock.
if it does need a hand brake, it won't pass an MOT with a hydraulic one
________________________
posted on 6/1/11 at 01:09 PM Reply With Quote
Hydrualic handbrakes don't meet IVA, MOT or Construction & Use requirements for a parking brake.
Line locks are Highly Illegal for road use in the UK and traffic police are well aware of line locks and will be discovered if your vehicle is subject to a spot check.
tony-devon
posted on 6/1/11 at 02:00 PM Reply With Quote
yup as they said, hydraulic is illegal,
rules clearly state mechanical
yes we require them for MOT and MSVA on trikes
they have to work on all the wheels on 1 axle, so you could a small cable operated spot caliper to the single wheel and that will be fine, or both wheels on a normal axle, as per my build
the trigger ones are very smart, stainless I think, range of mounting options
blakep82
posted on 6/1/11 at 02:03 PM Reply With Quote
have you got a link to them?
blue2cv
posted on 6/1/11 at 02:10 PM Reply With Quote
Richard Oakes is the designer, try trigger or www.blackjackzero.com
[Edited on 6/1/11 by blue2cv]
tony-devon
posted on 6/1/11 at 02:16 PM Reply With Quote
http://www.triggerhandbrakes.com/
they are beautiful, but as I have discovered in the custom bike world, just becasue it looks good, doesnt mean that it is good
hence why Im asking on here, in case anyone used or got one
might take a ride down and have a look at them if I decide to go for it.
even just so I can say I been to "water ma trout" especially as I come from the only place in the UK to have an ! mark in the village name
m4maverick
posted on 6/1/11 at 02:25 PM Reply With Quote
Hi, I have used the trigger handbrake to replace the standard sierra style on a Tiger Avon. I mounted it almost vertically on the LHS of the tunnel. Great bit of kit would certainly recommend it. Works well and was easy to mount.
Don't have any photos unfortunately.
It is expensive unless you get lucky, but in my view it did the job nicely.
Mike W
SeaBass
posted on 6/1/11 at 02:55 PM Reply With Quote
ROFL at people flippin out about hydraulic handbrakes when it's not even what the OP has posted about!!
MikeR
posted on 6/1/11 at 02:58 PM Reply With Quote
I thinks people have made an assumption as to what a 'trigger' hand brake is.
I've just been to the web site - they're cool (cable) handbrakes!
blakep82
posted on 6/1/11 at 03:17 PM Reply With Quote
nope, the second post suggested a hydraulic handbrake, and thats how that started
mistergrumpy
posted on 6/1/11 at 03:32 PM Reply With Quote
I remember seeing them when I was building and it concerned me that they may get loose after a few goes and the teeth may slip aside the trigger tooth. Kinda form over function.
