pstirz
posted on 15/1/11 at 06:58 PM |
rear brake pipe route
I'm a bit unsure of the best route for the rear brake pipes. I've run a single line on the drivers side lower transmission tunnel tube. I
intend to mount a 'T' piece behind the diff.
Has anyone got any photos or a description of the best route around the diff and to each side at the rear.
Cheers Paul
phelpsa
posted on 15/1/11 at 07:00 PM |
IRS or live axle?
HappyFather
posted on 15/1/11 at 07:42 PM |
If IRS, you can check pics of mine on my blog: http://happyblade.blogspot.com/2010/12/finishing-up-rear-brake-pipe.html
Note that I've run the brake pipe on the upper drivers side (and my car is Left Hand Drive). The pipe you see on the lower driver's side
is the fuel line. I believe most people do brake pipes on the upper side, but don't know if there is any special reason for that.
Have fun!
HappyFather
pstirz
posted on 15/1/11 at 08:19 PM |
Thanks for your help.
I got a IRS diff fitted.
Paul
bassett
posted on 16/1/11 at 10:58 AM |
Here should be a couple of picks of mine near the bottom of the page.
http://bassettsbuilddiary.blogspot.com/2008_03_01_archive.html
Id plan this carefully to make sure you dont obstruct access to the diff rear cover bolts and that it wont get squashed by the fuel tank. At the same
time might be worth planning your wiring so that the loom can share rivet holes for p clips saving time later.
Adam
