Author: Subject: Which compact Battery?
MakeEverything
posted on 20/1/11 at 10:18 PM Reply With Quote
Hi all,
Im looking at my boost hoses tomorrow, and realise that my battery is in the way of the inlet, and could really do with being smaller.
Can anyone recommend a smaller than normal high output battery?
I currently have a halfrauds Calcium battery which has lasted the lay-up and taken its charge well. Its a really good battery, and has plenty of poke.
Im open to thinking about a pair of motorcycle batteries parralelled, though would prefer a single compact hi-output car battery.
Kindest Regards,
Richard.
RazMan
posted on 20/1/11 at 10:24 PM Reply With Quote
Take a look at the Odyssey range - small enough to fit in really small spaces yet they pack enough poke to spin over a V8
Tiny Odyssey battery
[Edited on 20-1-11 by RazMan]
Raz
MakeEverything
posted on 20/1/11 at 10:27 PM Reply With Quote
Awesome, Thanks Razman. Ill give it a look. How much are they?
ETA: Razman! I called you Odyssey!!
[Edited on 20-1-11 by MakeEverything]
Kindest Regards,
Richard.
RazMan
posted on 20/1/11 at 10:35 PM Reply With Quote
Hee hee, I've been called worse
I think my one cost about £60 five years ago but I don't think they are much more nowadays. I think they are surprisingly good batteries and many people can't believe how much power they have in such a small package.
Here you go eBay Item
Raz
MakeEverything
posted on 20/1/11 at 10:46 PM Reply With Quote
Just made an offer on Odyssey PC680 motorsport battery on eBay (end time 28-Jan-11 08:57:37 GMT)
Kindest Regards,
Richard.
dhutch
posted on 20/1/11 at 10:50 PM Reply With Quote
Ive got the powerVamp branded version of the above, aquired it with the car, but i carnt fault it.
RazMan
posted on 20/1/11 at 10:51 PM Reply With Quote
Looks like a good deal for a 1 year old battery. Mine is 5 years old and still going strong - I keep it topped up on an Optimate charger and its as happy as Larry. Good luck with the offer
Raz
MakeEverything
posted on 20/1/11 at 10:56 PM Reply With Quote
Cheers Razman. I thought it was pretty good too. Im planning on installing "Anderson" type connectors so that i can plug in the charger and unplug without crocodile clips or messing around. Ive bought them, just need to fit them!
Kindest Regards,
Richard.
matt_gsxr
posted on 20/1/11 at 11:03 PM Reply With Quote
Couple of things.
You don't want to be putting batteries in parallel. They don't like it, as tiny voltage fluctuations cause problems. I know you aren't going to do this, but....
Second thing. For a charger (i.e. optimate or equivalent) you don't need anything as meaty as anderson plugs, as the current is not high from most chargers. It is a good idea to install a plug/socket arrangement (rather than the croc clips). I would also recommend that you fit the socket in the cabin so you don't have to open the bonnet (I fitted mine under the bonnet, but now its annoying to have to open that all the time).
MakeEverything
posted on 20/1/11 at 11:21 PM Reply With Quote
Originally posted by matt_gsxr
Couple of things.
UPS Systems use paralleled batteries (we use Yuasa) and theyre fine. In fact, the systems are designed that way.
I plan to mount the Anderson connectors behind the passenger seat, for ease of charging.
Kindest Regards,
Richard.
alawrence
posted on 21/1/11 at 06:40 AM Reply With Quote
batteries in parrallel are no problem
all large UPS systems, generators and Telecoms MTXs are full of them
MakeEverything
posted on 21/1/11 at 08:44 AM Reply With Quote
All ordered. Won it for a £50 offer.
Hopefully itll be here for the next phase of starting and tuning with the boost hoses attached.
Kindest Regards,
Richard.
ashg
posted on 21/1/11 at 08:49 AM Reply With Quote
should have looked at his feedback he has accepted loads of offers for £45
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
MakeEverything
posted on 21/1/11 at 09:17 AM Reply With Quote
Im not worried.
£50 is still a good price.
[Edited on 21-1-11 by MakeEverything]
Kindest Regards,
Richard.
