Author: Subject: Superchargers for small engines
liam.mccaffrey
posted on 24/1/11 at 09:50 PM Reply With Quote
Assuming there isn't an off the shelf supercharger solution for small engines (100cc-500cc)
Can anyone think of a small mechanical compressor which may may work?
Build Blog
Build Photo Album
MakeEverything
posted on 24/1/11 at 10:13 PM Reply With Quote
Id look for a small turbo for a 1L engine or even a normal one. Then look for a bleed valve or adjustable actuator to adjust boost pressure.
ETA: Same with superchargers, though they are rarely used on engines that small. The eaton M45 is the one from the mini which you may be able to change the pulley to a larger one to slow it down a bit. Check the compressor map before doing that though.
[Edited on 24-1-11 by MakeEverything]
Kindest Regards,
Richard.
PSpirine
posted on 24/1/11 at 10:27 PM Reply With Quote
Can you give a bit more information about the engine?
There are things like Smarts about they had 600cc turbo which is pretty small. But obviously still too big if this is going onto a lawnmower!
liam.mccaffrey
posted on 24/1/11 at 10:29 PM Reply With Quote
yeah good call, im looking at pressure ratios and compressor maps right now, I have an M62 for my other project incidentally
Build Blog
Build Photo Album
liam.mccaffrey
posted on 24/1/11 at 10:31 PM Reply With Quote
Can't give really elaborate much as it was a general question bout pressure charging small bike engines. I have nothing specific in mind
[Edited on 24/1/11 by liam.mccaffrey]
Build Blog
Build Photo Album
tomgregory2000
posted on 24/1/11 at 10:32 PM Reply With Quote
would a 100cc engine have enough power to even run a super charger?
tomgregory2000
liam.mccaffrey
posted on 24/1/11 at 10:34 PM Reply With Quote
A serious consideration, there's no way that small an engine could turn an eaton m42
Build Blog
Build Photo Album
tegwin
posted on 24/1/11 at 10:39 PM Reply With Quote
Do rotrex do anything that small?~
www.verticalhorizonsmedia.tv
PSpirine
posted on 24/1/11 at 10:46 PM Reply With Quote
Some reading:
http://www.elsberg-tuning.dk/supercharging.html
plentywahalla
posted on 24/1/11 at 10:47 PM Reply With Quote
Its a bit off the wall ... but some kerosene burners use a small air pump to atomise the fuel.
MakeEverything
posted on 24/1/11 at 11:17 PM Reply With Quote
Good call. Initially, thats all superchargers were designed for, Air pumps on furnaces. - Apparently.
Kindest Regards,
Richard.
gator
posted on 24/1/11 at 11:28 PM Reply With Quote
If you really must, AMR300 and AMR500 are 300cc and 500cc respectively. Off small Jap Kei cars (Subaru?). They come up from time to time on fleabay from the jap importers in Oz, so I guess they are available elsewhere.
Regards
Alan
http://cgi.ebay.com.au/Genuine-AMR300-Supercharger-Pocket-Bike-moris-mini-moke-/230574596489?pt=AU_Car_Parts_Accessories&hash=item35af512189
PSpirine
posted on 24/1/11 at 11:32 PM Reply With Quote
The AMR300 and 500 are Aisin superchargers - sometimes helps to search by Aisin rather than by the particular name. I noticed a lot of places just list it as a Aisin supercharger for YYYYY vehicle.
They're not what I'd call tiny though.. certainly quite chunky for a 100cc motor!
liam.mccaffrey
posted on 25/1/11 at 12:02 AM Reply With Quote
Cool all good info chaps
Build Blog
Build Photo Album
dlatch
posted on 25/1/11 at 12:22 AM Reply With Quote
there is a peugeot scooter 125 cc with a super charger
would assume that would be perfect its called a jetforce or something similar
bimbleuk
posted on 25/1/11 at 09:21 AM Reply With Quote
Damn beaten to both my answers! I was also going to reference the Kei class supercharger and the Peugeot scooter as I want to buy one for hooning to work on.
Have a search on autospeed.com for old articles about the kei class imports
posted on 25/1/11 at 09:32 AM Reply With Quote
I'm struggling to see the point of the Peugeot supercharged scooter. Complicated, bulky, heavier and very likely thirstier than a 250cc engine, and since you are restricted on power as a learner on a 125cc bike, it doesn't get around this.
pewe
posted on 25/1/11 at 09:39 AM Reply With Quote
My understanding is that a supercharger soaks 10% of the power just spinning it up.
If you must go down the forced induction route surely turbo has to be the way to go given it's power is "free"?
Cheers, Pewe
RazMan
posted on 25/1/11 at 09:40 AM Reply With Quote
http://www.youtube.com/watch?v=IGOG-R3ZwDA
Raz
coyoteboy
posted on 25/1/11 at 11:45 AM Reply With Quote
Turbo power is not free, that's a bit of a misconception, it is just lower loss than a supercharger. But it provides a different set of problems/benefits. General thought process is that turbos are good for all out power (drag), and SC are good for drivability, but that's dependant on what turbo or SC you choose etc.
Check out some of the FSAE / Formula Student turbocharged cars, they generally use super small turbo/superchargers as they're limited to 600cc engines max (many run smaller) and pretty hefty throttle restrictors.
[Edited on 25/1/11 by coyoteboy]
Mr Whippy
posted on 25/1/11 at 12:25 PM Reply With Quote
how small can you go?
blakep82
posted on 25/1/11 at 12:30 PM Reply With Quote
yep, was just thinking of r/c engines being supercharged. it does happen!
________________________
