Author: Subject: camber and caster
david
posted on 25/1/11 at 11:49 PM Reply With Quote
camber and caster
what is the proper measurement for the above on an MK. David
interestedparty
posted on 26/1/11 at 06:17 AM Reply With Quote
I suggest you try MK for that information. If there is some reason why you don't want to, then start with 1 degree negative camber and 5 degrees of caster.
whitestu
posted on 26/1/11 at 08:35 AM Reply With Quote
I agree, start with 5 degrees, although I found that 5 degrees of castor wasn't enough to give enough self centring. Mine has 6.5 degrees now [via modified wishbones]
Stu
RazMan
posted on 26/1/11 at 10:10 AM Reply With Quote
I degree of camber is about right for the road - a little more for the track
Raz
