craig_007
posted on 27/1/11 at 07:56 PM |
Alloy bracket for tdc sensor
I know this is a long shot but I'm wondering if anyone would be willing knock me up a bracket.
It would need to be 150mm long x 40mm wide and anywhere between 5mm to 10mm thick, It's for holding a TDC sensor in place so has to be rigid.
Thanks in advance
[Edited on 27/1/11 by craig_007]
daviep
posted on 27/1/11 at 08:26 PM |
How quickly do you need it? I may be able to help.
Regards
Davie
craig_007
posted on 27/1/11 at 09:23 PM |
No real rush at all.
Just thinking ahead really.
Would be much appreciated though.
mcerd1
posted on 28/1/11 at 09:34 AM |
what sort of thing did you have in mind ?
just a bit of shaped flat or bent & welded or machined billet or something else.....
daviep
posted on 29/1/11 at 08:06 PM |
Had a look in the garage today, I've got nice piece of ally 8mm thick which I can use, drop me a u2u or post the design and I'll let you
know how long it'll take.
Davie
craig_007
posted on 2/2/11 at 10:32 PM |
Hi thanks for that much appreciated.
I did manage to get a bit 10mm steel from a friend and hopefully that will do.
Thanks again all the same.
Craig
daviep
posted on 5/2/11 at 10:38 PM |
If you ever need material drop me a line, got loads of scrap lying about, also have a lathe and a mill if you need bits machined.
Davie
