Author: Subject: Tin Top Advice
roadrunner
posted on 4/2/11 at 01:16 PM Reply With Quote
Tin Top Advice
I have a 1.8turbo passat and it seems to be using more fuel than I would expect it to use.
Now when I had a 2.3v5 golf i could get over 40 to the gallon, with the passat I get around 30-35 mpg.
I have noticed that the car is more responsive when the engine is cold and when the engine is fully warmed up the temp reads about 80degrees and doesn't touch the standard 90degrees, the tick over is fine when warmed up to around 800revs.
Where would be a good place to start looking.
Brad.
P.S. Thinking of getting re-mapped also to over 190HP.
[Edited on 4/2/11 by roadrunner]
posted on 4/2/11 at 01:35 PM Reply With Quote
Has it got a MAF sensor ? Symptoms fit.
On Rovers with BMW engines we disconnect them to test if they are within calibration, without the signal from the MAF the engine ECU switches to a default injection map if it runs better the MAF is foobared.
[Edited on 4/2/11 by britishtrident]
roadrunner
posted on 4/2/11 at 01:40 PM Reply With Quote
So how would mine run better, the mpg or the engine is more responsive.
monkeyarms
posted on 4/2/11 at 01:42 PM Reply With Quote
Check your tyre pressures.
My 1.9tdi PD Passat would show lower (although not much) mpg when a tyre or 2 went low.
[Edited on 4/2/11 by monkeyarms]
posted on 4/2/11 at 01:45 PM Reply With Quote
Do a google on MAF sensor symptoms or VW MAF sensor.
roadrunner
posted on 4/2/11 at 02:01 PM Reply With Quote
First thing i always check.
roadrunner
posted on 4/2/11 at 02:32 PM Reply With Quote
Just disconnected the maf sensor and went for a spin.
Now , it did seem to be more responsive but the idle was rough and it kept stalling at junctions, then the cat warning light came on.
What do you think.
Brad.
posted on 4/2/11 at 07:18 PM Reply With Quote
Has the mpg of the Passat actually got worse? i.e. were you getting 40+mpg and now only 30-35mpg?
roadrunner
posted on 4/2/11 at 08:09 PM Reply With Quote
No, I have only had it a month.
roadrunner
posted on 5/2/11 at 01:52 PM Reply With Quote
bump.
car builder
posted on 5/2/11 at 07:26 PM Reply With Quote
sounds like either coolant temp sensor or thermostat as you say its not getting to 90 the ecu is running it richer as it thinks the engine is colder then it is.
roadrunner
posted on 5/2/11 at 08:17 PM Reply With Quote
I think I will clean the maf with spray cleaner just to help and then change temp sender and thermostat as they are cheap to buy first.
Thanks for the info fellas.
Brad
