MikeFellows
posted on 7/2/11 at 11:45 AM |
08+ Busa/B-King Engine Info
Ive been doing some research of late and came across a staggering bit of information on hayabusa.org
on 08+ engine I can connect a home made cable to the ecu and have more mapping control than any plugin could possibly give, all limits can be removed
and you can also remove the o2 sensor
I also found out the TRE is completely pointless on a 08+ engine as it doesn't work. as it forces the bike to use the same fuelling through all
gears.
why are people using power commanders at £100's of pounds when a simple cable and laptop will do the job.
the software to manage it looks as good as any.
is anybody using it or am i going to be a guinea pig?
Link to Hayabusa.org original
article, its 57 pages but a very good read
SJL
posted on 7/2/11 at 07:00 PM |
I have built the interface for my 07 engine,initially I only used the fault code reading side of it but do now have communication with the ECU
properly now.
Just need to grow a pair and flash it to remove the lower gear limiter(tre mod effectively)
I have mentioned it on here before - just last week actually
The 08 has loads more functions and features within the ECU compared to the 07 and older stuff. You have got to love reverse engineering.
MikeFellows
posted on 7/2/11 at 09:30 PM |
I was amazed.
I was close to spending £500 on a power commander and today ive ordered £22 worth of bits with the plan to end up with a nice femal usb connector and
switch mounted next to the ECU.
the latest software can also conver power commander maps
its brilliant
noc231073
posted on 8/2/11 at 02:50 PM |
Very interesting stuff I'll be watching closely to she how it works out before I order a power comander
SJL
posted on 27/2/11 at 07:07 PM |
Just to update
I successfully reflashed my ECU on Friday and it all works very well
Highly recommended
noc231073
posted on 27/2/11 at 08:47 PM |
just got mine sorted got the lead from smithy and ready to flash
[Edited on 27/2/11 by noc231073]
