907
posted on 7/2/11 at 08:20 PM |
Fuel proof rubber bobbins
Hi All,
Does anyone know of fuel proof rubber mounts, suitable for mounting a fuel pump in the tank?
Is there a tin top (or bike) that uses "in tank" rubber mounts?
I seem to have drawn a blank.
Many thanks,
Paul G
posted on 7/2/11 at 08:43 PM |
Can't think of any Paul, all of the in tank pumps I know of sit on top of the tank and are held in place by a retaining collar.
posted on 7/2/11 at 08:56 PM |
Easiest way to mount a injection pump inside a tank is to use the Rover 600 pump assembly which uses a neat bolted flange mounting.
25 & 800 are
similars
[Edited on 7/2/11 by britishtrident]
907
posted on 7/2/11 at 10:32 PM |
Cheers Mel and BT.
I already have the pump. A tad bigger than the Rover one.
Just need a way of mounting it in the bottom of what will be quite a deep tank.
Apparently the rubber that's fuel proof is called nitrile.
I'll keep looking.
Paul G
Killer
posted on 8/2/11 at 09:10 AM |
Hi Paul, I got one of these bigger ones for my exhaust but they may do smaller ones, Anti Vibration Mount / Rubber Bobbin Mounting
M10 B4040 on eBay (end time 30-Jan-11 14:28:36 GMT)
Rich
MikeCapon
posted on 8/2/11 at 09:23 AM |
I'll keep looking.
Paul G
Hi Paul. If you are looking for suitable nitrile components that may do the trick, most O rings are nitrile. The standard O ring material is NBR 70
(Nitrile Butadene Rubber) the 70 is the hardness. You may also find NBR80 (harder) and NBR90 harder still.
I can't vouch for the resistance to fuel but if you're sure on that you could use large cord O rings either side of your mounting bracket?
907
posted on 8/2/11 at 07:36 PM |
Hi Mike,
I'm trying to do this with no metal to metal contact so I'm not sure if I can do that with O rings.
Good info though. That's bound to come in handy.
Hi Rich,
Followed that link, found their website, and emailed them.
Got a reply back this afternoon requesting the weight of the pump (3 kg) so they could suggest the
right "Nitrile" ones to use. Just waiting for a price now. Magic. Thanks.
Cheers to all.
Paul G
