Author: Subject: Handbrake options
dave
posted on 11/2/11 at 10:00 PM Reply With Quote
Handbrake options
I have had the Sierra one fitted and kept banging my elbow, so now I'm looking for alternatives eg something under the dash. Any idea's
posted on 11/2/11 at 10:11 PM Reply With Quote
Look at fitting a MG Midget handbrake in the passengers side.
posted on 11/2/11 at 10:22 PM Reply With Quote
Why not use the sierra on in the passenger area. That's what I did... works nicely.
hootsno1
posted on 11/2/11 at 10:26 PM Reply With Quote
Older Jag's had them under the dash pull it up to hold the wheels then pull and let go to very neat and can be fitted down the side of the seat
dave
posted on 11/2/11 at 10:27 PM Reply With Quote
Ben how did you connect the cables
paulf
posted on 11/2/11 at 10:51 PM Reply With Quote
Metros had a nice compact hand brake lever I used one on mine, easily mounted with 2 bolts and the cable is a single barrel nipple type connection.
Paul
Steve Hignett
posted on 11/2/11 at 11:11 PM Reply With Quote
Mount the Hbrake lower/underneath the existing mounts?
Follow the Hbrake shortening guide by metal hippy or someone else?
Do away with it altogether like I did!
T66
posted on 12/2/11 at 07:50 AM Reply With Quote
We are looking at a Hilux under dash handbrake for my Fiat
[Edited on 12/2/11 by T66]
dave
posted on 12/2/11 at 10:32 AM Reply With Quote
Off to the breakers to get some inspiration.
The Black Flash
posted on 13/2/11 at 01:53 PM Reply With Quote
I mounted mine vertically, level with the dash:
I made a reversing linkage so that I could run the cable out of the front, rather than the back:
i_froloshki
posted on 1/7/11 at 09:48 AM Reply With Quote
Hi, does anybody know if the front handbrake cable for dax is dax manufactured or is taken (or look like) from some other car?
Thanks in advance
Regards
Yavor
