nick-york
posted on 12/2/11 at 10:45 AM |
expansion tank ?
I have a crossflow engine fitted but i can t find any information about the cooling system anywhere . In the chris gibbs book there does not seem to
be an expansion tank for the radiator . I know that because the radiator is fitted so low it has to be topped up through the top of the thermostat
housing.But i would be happier if i had an expansion tank for easy monitering of coolant levels .If one was mounted near the battery it would be
higher up than the radiator.Is it normal practice to have an expansion tank on a crossflow or unheard of ? Also i am not fitting a windscreen heater
so what alterations would i need to make to the plumbing .If any ?Last of all ! Has anybody got any pictures on here of crossflow pipework ? Any
advice much appreciated .
bob
posted on 12/2/11 at 12:31 PM |
Have a look in David Jenkins photo archive, i am sure this question has come up before and a picture of davids set up was pointed to.
mrwibble
posted on 12/2/11 at 12:34 PM |
in that case a search might prove useful,
the logic seems sound however, can i ask whether you need to think about demisting options if its going to be IVA'd?
[Edited on 12/2/11 by mrwibble]
wicket
posted on 12/2/11 at 12:36 PM |
See my photo archive/wicket/cooling system/x-flow_plumbing.jpg for diagram.
Rich J
posted on 12/2/11 at 12:43 PM |
Heres the set up on my Stiker when I bought it
The expansion tank was fitted on the bulkhead with the outlet connected by a "T" piece into the bottom hose via the red pipe running under
the alternator. There was also a smaller pipe running to the Fiesta type thermostat cover (just visible withe green tape on it). System seemed to work
well.
Hope this helps a bit
prawnabie
posted on 12/2/11 at 02:07 PM |
I think you are mixing expansion tank up with header tank.
Expansion tank runs off the take off from the radiator cap.
nick-york
posted on 13/2/11 at 12:11 AM |
I was nt going to fit a windscreen till after IVA then put a heated screen in .
nick-york
posted on 13/2/11 at 12:16 AM |
Whether its an expansion tank or header tank or even both i don t really know . I just knew sort of what i wanted but did nt know how to do it ! The
diagram and photos were just what i needed . Thanks everyone !
